how do i know if my camaro is a true iroc?
Old 05-24-2013, 06:40 PM
3rdgenowner's Avatar
Car: 89 camaro rs
Engine: 350 tbi
Hi guys, I am new and have a very important question,
I just bought a 86 iroc z28 and I am wondering it it's a true iroc.how do I tell?
Thanks to all of you so much for helping me.
Old 05-24-2013, 10:18 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: how do i know if my camaro is a true iroc?
Use the search box; plenty of info there. Here's a freebie: open your center console. On the lid or against a wall should be a RPO sticker. If its there,
Step 1: make sure the vin on the sticker matches your car (lids and consoles can be swapped if damaged).
Step 2: if you have the correct sticker, one code should be B4Z, which designates Iroc.
Other items separate the Irocs from regular z28s. The search feature will help with that.
Old 05-24-2013, 10:47 PM
Car: 89 camaro rs
Engine: 350 tbi
Thank you so much...parts id card in the console has the "b4z" and "z28" and the vin matches the vin on the title...so it is a iroc z28the badge inside just says "camaro"not "z28 iroc"...so that's why I was confused.
It does have the tbi 305 and t-tops with rear drum brakes which I believe were optional in 86 correct?
Thanks again buddy.
Old 05-25-2013, 12:19 PM
majobis's Avatar
Axle/Gears: G92
Take a clear photo of your RPO code sticker and download it to your computer. This will act as a reference point while you search between this site and google looking up 'RPO decoder'. You should be able to learn what 90% of those codes are. Keep in mind that 27 years and multiple owners later, things may have been changed on your car; drums to discs as an example. Good luck!
Old 05-25-2013, 01:21 PM
Car: 89 camaro rs
Engine: 350 tbi
Thank you buddy, will do
BlueIroc-Z
06-09-2019 03:22 AM
okfoz
03-09-2017 02:35 PM
CarGuyDennis
137
12-06-2016 11:02 PM
Derick15
09-17-2016 05:28 PM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: how do i know if my camaro is a true iroc?
