gauging interest - FUNCTIONAL HOOD LOUVERS
TGO,
I know this sounds like a broke record....
I have been talking to a guy that makes louvers (among other things). After talking to him on the phone he basically said that he wants to be able to sale more than a few sets otherwise it would not be worth the effort.
Here are the louvers that I am ordering (see below). I am trying to get him to modify his cad design of these louvers into the shape of a Stock IROC louver. If there is enough interest, he might even make a whole new design all together.
Who is interested??
Who is interested??
Re: gauging interest - FUNCTIONAL HOOD LOUVERS
Here is a pic of some of his louvers being made
They come as a flat piece of metal (images shown are not the same louvers as posted above, but same concept)
Here they are after being properly bent before installation
If I cannot get anyone else on-board, I will just have him do mine and be done with it. The pair of louvers on the red car above are the louvers I am ordering btw... At some point I'm hoping to send him a set of IROC louvers.
I told him that I had 15 people interested, he said that would be enough
Here is what they look like from the bottom
I like the idea, but it looks like they take a lot of precious under-hood room. Certainly will cause air cleaner clearance issues for carbureted and TBI cars.
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
I'd be interested in a set that mimicked the IROC louvers, provided under hood clearance was good. Plan on going carb soon, I need that clearance.
Car: 88 iroc vert
i might be interested if he could get them almost the identical to the stock louvers, or fit inside the dented area where the louvers go. and if the price isnt too outrageous
I'd think you would have more interest if they mimiced the stock louvers but were functional.
Looks like the only function they serve is to let some heat out and let a lot of water in. If your car is a fair weather only car then that's one thing but I just don't see any good reasons to make the hood louvers on these cars functional. I imagine that's why you don't have many takers. JMO
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Agreed. However, these might work for me, but they would have to fit stock location, just cut a hole. Price?
This also adds some front down force look at the wind tunnel results of the newish ford gt or the zl1.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Seriously, you think just the extractor is going to give you downforce?
It's an extractor, it just pulls heat from the engine bay. On our cars that also helps pull air through the radiator.
I think extractors are a good idea on most cars.
This one looks pretty good, but it's overly complicated and takes up too muck space for third gens. The same thing can be done in composites much more easily and even in aluminum should be able to be done without taking up so much Underhood space.
Car: 02wrx/88 rs
I do.
Much or measurable amount? No. It would help make a lower pressure air under the car. Also depends on the way they overlap. How the air over them would pull the hot air out.
Well, you're wrong.
It would allow an air release for hot air of the engine compartment. In order to decrease pressure under the car (creating downforce) you have to control the air moving under the car with splitter, skirts, etc.
If you read more about the new vette z06 you will note that they describe it as the first American car to have measurable downforce from the factory. Even so, it has to be going pretty fast to do it.
Take a shop vac and put the nozzle straight down on a flat surface. Note that it has lots of "downforce" when sealed to the surface. As soon as you lift it even slightly off the surface, no more downforce. Lots of negative pressure inside the vac tube, but no down force as it only takes a small leak of air to equalize pressure and eliminate the force.
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Well, you're wrong.
About hood louvers. The factory cooling system brings air in from the front of the car and exhausts it down to the ground under the car. The most common method to create downforce in race cars is to limit the amount of air that goes under the car and seal the sides; in other words seal off the front with a low air dam or splitter, seal the sides with low skirts and route your cooling system air out of the hood or the sides of the car. Hood louvers allow more air to go out through the hood rather than under the car, therefore creating some down force. Splitters and skirts are additional aids to create DF.
Do I think louvers by themselves are going to create a noticeable difference on an otherwise stock car? Probably not to most people but it could be one of those incremental things. On a car with a splitter or low front air dam and sliding skirts it will probably make a larger improvement. Some rather generic cl numbers are given in some books for different types of engine cooling systems types.
Some of your points are valid but others are not completely true. The vacuum cleaner analogy is mostly true, but as you get away from the ground there is still DF but it is much less. Youtube 'ground effect'.
Car: 87 IROC
Engine: 5.3L
With good sensors and good repeatable testing I'm pretty sure you could measure a difference.
1 Post
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Just a thought, the base of the windshield is a huge high pressure area on the car. It may be better to not use the last 4" or so if you're putting them in same location as the stock louvers. If you can move them I'd go forward with them until they start just behind the radiator support.
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
I would be interested if the price and clearance were right (matching stock).
Thirdgens are awesome cars great fun ti drive sexy to look at but once you get past 120mph the handling isnt too hot. Ive got my 89 formula350 gave my 01 ws6 transam to the wife. The ta handles like a dream at 150mph on curves the formula starts getting scary at 120ish on a perfectly flat straight road.
Adding functional vents is not going to change those issues at speed. At slower speeds functional louvers are a novelty so most folks will think its a cool idea which it is but it serves no real purpose.
When i push the ta up past 120 you can start feeling the car hunkering down and the steering getting a little stiffer and more response to less input.
When you take the ttops off and get around 100-120 you can feel the back end starting to bounce as its losing grip. The faster you go the scarier it gets. Around 130 i can actually feel the rear end popping up and starting to lose control.
Depends on what your calling downforce. But when your car is no longer aerodynamic things go to hell quick.
My advice dont stick things to your car or remove them without careful testing if you plan on going stupid fast.
I am doing louvers to my cowl hood on the sides of cowl to vent heat, not on cowl itself. These louvers look nice tho in the pics. How much they cost?
My iroc feels fine over 120-140. Havent been over that, just quarter mile runs it feels fine even on bias tires. May see 160's this year. Hope it remains stable but the vents for me are for heat extraction only lol primary concern
How much for a set of these exact ones? I have a 4" cowl hood for a firebird and would love a set of custom hood Louvers like these! If u can give me his contact into I would also appreciate it.
My hood gets very hot bc it has a 521 BBF under it and I've been researched where good extractor can help get the heat out and help cool my engine more.
Depends on price. They do look amazing. Clever to bend two tabs to angle the individual louvers. I also have access to a CNC machine, it wouldn't be horrible to template that, and maybe it could be done with 040 or 060 aircraft aluminum.. Cost on something like that isn't too much other than owning the CNC machine and handling 4x8 aluminum sheets.
That's why I say depends on the price. Regarding needing a bulk order.... How is it not worth it to let the CNC machine cut out one set? He can use any leftover aluminum on the sheet for other projects. It seems the only labor involves bending the individual louvers and de-burring edges.
Car: 91 Camaro Z-28 Convertible
Engine: 5.0
I would like to see an installed set, and am very interested.
Car: Check The Sig
I'd like to see a tray under the vents much like the new Camaro SS and ZL1 have. There is a tray that allows air to escape up and out from under the hood while making sure water drains away from vital parts.
Like so
Like so
For $100, if it matched the current louvers I would buy. But I need the clearance. My TBI already touches my hood with my K&N Filter top.
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
If there a link on the web site http://vraptorspeedworks.com/custom-roadster-parts/ to buy a set of these?
His louvers are only about $100/set, but the IROC louvers would be a custom design. There is no way that I can guarantee that kind of pricing, but I'm quite sure they would be cheaper if we had more takers.
colton_carlson
03-08-2019 12:21 PM
ambainb
04-25-2016 09:21 PM
86IROC112
08-17-2015 02:00 PM
