4th Gen style spoiler with louvers??
Question is can you use a 4th gen style spoiler with window louvers?
I am considering the purchase of a 4th gen style hood that is meant for the third gens. I have louvers on the car and love the way they look, and I don't want to lose them. I would consider a different set of louvers if necessary.
I want to know if anyone has done this and if so what louvers did they use?
Location: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Re: 4th Gen style spoiler with louvers??
Personally, I'd go with '91/92 TA spoiler instead. Those 4th gen spoilers were designed for the more rounded look of the 4th gens. The '91/92 spoiler essentially is the same, just shorter and were designed to look good on 3rd gens.
Car: 1987 Pontiac Firebird Standard
Engine: 2.8L V6
Transmission: Automatic
You would most likely need to find a set of louvers for the wrap around style spoiler. But there is no guarantee that the third gen wrap around louvers will worth with the fourth gen wrap around spoiler. I would consider what MintWS6FORMULA said above.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am 90% sure the Factory louvers would not work... I am not even sure if there was any aftermarket louvers that worked with the factory spoiler which I would think would be the only way to do it.
AkDrifted
08-17-2015 07:45 PM
