Cowl hood air cleaner height?
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
I purchased a 2in amd cowl hood and was wondering how tall of an air cleaner I should buy. It will be going on top of a 355 w/ edlebrock air gap intake and a Holley 760 carb . Thanks for your input .
Re: Cowl hood air cleaner height?
Not 100% apples to apples but friend of mine has a 2" cowl, air gap manifold and edelbrock 1405
He runs a K&N filter kit
http://www.knfilters.com/search/prod...x?prod=60-1150
Then later he upgraded to this filter to fill the cowl a bit
http://www.knfilters.com/search/prod...px?prod=e-1220
Engine: 355 SBC
Thanks for the info , I'm hoping to go taller then a 2.5 but that is a good starting point .
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
If your running the drop base, you should be able to fit a 4" without any problem.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
one problem is the camaro engine isn't centered in the car.the air breather will hit the edge of the opening in the hood.or it did on my car.
Engine: 355 SBC
I read that if I go with a 11in air cleaner it won't hit the hood . I'm prob gonna go with an 11x3 with the xtream lid and a flat base . Hopefully that will fit .
ElPaleterro85
08-13-2015 03:49 PM
