Rear quarter panel damage
Car: 91 & 90 Camaro RS
Engine: 305 TBI
Transmission: Manual T-5
Is this damage repairable? I spun out on the freeway hit the center divider. My brother is saying we can try pulling it out. What do you think?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Rear quarter panel damage
Looks like a easy fix, especially if you can weld. Most of the damage looks to be on parts that you can just replace(lights, bumper cover, GFX). Did you shatter the hatch glass? If not, you can pull out the dent or just cut out the damaged quarter panel area and weld in a new section.
Engine: 305 TBI
Hatch glass is intact thankfully (as well as louvers). Ok, that's what I wanted to hear, honestly I just need some motivation right now. I guess I will try pulling it out first, then cutting if I cant get it to look right. Ya all the other parts do look easy to fix. I'm anxious to see how the rear hatch lines up once its all back to normal. I will post some "after" pics once im done.
Car: 1992 Camaro RS
You may not need to pull it out. That area is pretty accessible from the inside once you remove the plastics and spare tire.
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
His car is wearing the spare I think.
(and by a strange coincidence so is mine - in the exact same place)
I think that can be easily fixed. My quarter was smashed up pretty good and do to a butchered bondo job, it had to be replaced andd the aftermarket goodmark product is pretty good.
I think you should be fine with your quarter though. Strip it and go from there, but it doesnt look too bad.
1992 Trans Am
05-10-2023 07:19 PM
