Firebird mirrors on a Camaro
Car: 1991 Camaro RS
Engine: 305ci TBI
Transmission: 700R4 Built
Axle/Gears: 3.73 Eaton Trutrac 10-bolt
Hi All,
Bit of background information. I have a 1991 RS which was an export model, so comes with electric fold away plastic mirrors. I've always wanted the standard metal aero style mirrors.
Can you swap a set of mirrors from a Pontiac Firebird on to a Camaro? I'm going to assume the bolt holes for these plastic mirrors will be the same as the standard ones, I just need to know if those from a Firebird are the same as the ones on a Camaro. It's much easier to find electric mirrors for a Firebird than a Camaro.
Cheers all,
Andy
Cheers all,
Andy
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Firebird mirrors on a Camaro
Mirrors are the same. Power mirror harness and switch are different, everything else is the same
Car: 1991 Camaro RS
Engine: 305ci TBI
Cheers for the replies guys!
Can I assume it'll just be a case of splicing the existing wires to the new mirrors then?
Not overly fussed about them working. Got to admit for the last three years I've owned the car I don't remember touching them!
No, not even that big a deal. The connectors at the door are the same, it's all plug and play.
I should have been clearer in saying that the control switches and where the switches connect to the harness are different between firebird and camaro.
Car: 1991 Camaro RS
Engine: 305ci TBI
I shall go ahead and get these other mirrors and have a play.
Thanks all!
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
FWIW, on many electrical connectors you can remove each wire via a small tab so you may not have to splice the wiring. It's called "repinning a connector" if you want to google it.
When you buy the used mirrors make sure the gasket interface is in good condition. I don't know what you have but it may be shaped differently as well.
