Anyone know what these clips are called or where to get them?
Car: 1988 Camaro Iroc-Z
Engine: 350 TBI
First off, I apologize if this is in the wrong board.
When I bought this 88 IROC, it didn't have any hood struts. I have a new set of struts, but I need some sort of clip to hold it in and I'm not sure what they are. I found this clip in the trunk of the car and it seems to work, but when I searched for them I couldn't find them. It closely resemble the clip used on the door lock rod. Any help would be appreciated, sorry if this is a stupid question!
Car: 1986 IROC Z
Re: Anyone know what these clips are called or where to get them?
Just did a full brake job on mine and it looks like the clip that holds the soft brake line in place near the wheels.
Engine: 350 TBI
You're right, that's the clip. I suppose this isn't the right clip for the struts then. Hmmm.
Engine: 350 TBI
Well, I found this and it looks like the same clip. Maybe I can get away with using the brake hose clips.
http://www.ebay.com/itm/HOOD-ASSIST-ROD-CLIP-NOS-GM-1982-1992-CAMARO-FIREBIRD-S821-/151934525016?hash=item236000de58%3Am%3AmItwu-r0S3W8XguXqxh3iFA&vxp=mtr&nma=true&si=IRxMLnWBIQSnjhi5TGA22RXlF1Y%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Transmission: 5-Speed Manual
New Lift Supports Come With Clips On Them.
The clip you need goes where the rubber line transitions to the hard line.It should open, so it can slip into place.There is also a small bracket that bolts to the strut, which the brake line fits into.That clip holds it inplace.
Original Poster Clearly Says "Hood Struts".
Engine: 350 TBI
lol, it's all good, I should have specified in the title. I actually got a set of the clips I needed for the struts from a member! Thank you everyone for your replies, it's greatly appreciated.
Those are positively OEM hood strut retainers. I have 4 of these cars and only one still has the OEM struts and that is the retainer. (and there a bear to get off without bending them) The after market struts come with a different type of retainer. I know this issues was subsequently solved but I'm throwing in my 5 cents (inflation) so that anybody who reads this thread in the future can have certainty.
I changed my hood struts today and that's definitely the clip that held them. New $15 ebay struts came with new clips.
That's definitely NOT a hood strut clip
This is:
It's a brake line clip, used on struts and hardline to subframe connections
Dorman
UPC: 37495139878
GM OE# 22555667
Ford OE#: N800968-S436
Car: 1985 Camaro Z28
Engine: LG4
Transmission: 3-Speed Automatic with Overdrive
I'm going with hood strut.
rh76camaro
01-13-2016 11:31 AM
