putting on stands when rear axle is broke loose on passenger side
Old 05-06-2016, 11:44 AM
slowboy's Avatar
Car: 1990 CAMARO RS
Engine: 350 - replaced 305 with 350
Transmission: 5 SPEED
Axle/Gears: STOCK [?]
1990 Camaro RS was wrecked and broke passenger side of rear end/axle loose...how do I get this up on jack stands so I can get underneath car?
Thank you,
slowboy
[Keith]
Attached Thumbnails putting on stands when rear axle is broke loose on passenger side-img_20151222_141620091.jpg
Old 05-06-2016, 01:09 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: putting on stands when rear axle is broke loose on passenger side
Put jack stands on the chassis right in front of where the rear lower control arm attaches to the chassis
Old 05-06-2016, 02:18 PM
slowboy's Avatar
Car: 1990 CAMARO RS
Thanks for reply, but I need to know 'how/where' to jack it up to be able to put jack stands under it please. I know 'where' to put the stands once up high enough.
Old 05-06-2016, 03:29 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Transmission: Dynamic Racing Reverse Manual 700r4
Axle/Gears: 9 Bolt 3.45
see if you can jack up on the sub frame right next to where you'll be putting the jack stand (infront of LCA mounting place).
racing28x
Members Camaros
03-16-2017 02:55 PM
91RS5speed
04-07-2016 06:53 PM
gmancamp
Interior Parts Wanted
03-31-2016 03:47 PM
ecstasyrs
03-28-2016 12:11 AM
86IROC112
03-24-2016 10:00 AM
Quick Reply: putting on stands when rear axle is broke loose on passenger side
