HELP!!! Installing Hawks body side moldings
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Hello I'm painting one of my 87 Irocs in a few days. I removed the old thin moldings and ordered the wider set of door moldings that install horizontally on the door and front fenders. I'm not sure how to cut these so they look good and how to get the right angle on the area where the door and front fender meet. has anyone done this? I just don't want to ruin $100 moldings and make the car look wrong and throw them away. Thanks Chris
Re: HELP!!! Installing Hawks body side moldings
BUMP!!!
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
$100 set of moldings isn't pre-cut and ready to apply?
I had to cut them carefully to make them as perfect as I could. I used a used set as a guide for measurements and cut angles. I looked at a few pics of mounting points to get the spacing right. we'll see.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Put the points on first - leaving room on the fender for the door opening and swinging. Use 3M double sided tape - don't cheap out. Then, stretch masking tape along the line between the points as a guide. Put the long piece on the door, then use a heat gun to secure them all.
There are no metrics that I know of. Look at other cars, use your best judgment, and keep it straight.
dennisbernal91z
04-14-2016 05:42 AM
