Replacement outer door handle. Are all the aftermarket handles the same?
Old 08-23-2016, 04:59 PM
BrianI's Avatar
I have replaced my driver side outer handle before and it just doesn't feel right. When pulling up on the handle , both sides don't go straight up. Going to try another handle but was wondering about the quality. Are they all the same? Seems like I bought this one from Classic Industries but I'm not positive. Thanks
Old 08-23-2016, 08:09 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Replacement outer door handle. Are all the aftermarket handles the same?
Most of the aftermarket handles I bought from any supplier were china
specials. Not just for the camaro either. The ones for the Olds or Chevy
were the same quality.
I doubt they will last for 25 YEARS like the OE GM factory pieces...............
Old 08-23-2016, 09:53 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Most (if not all) aftermarket handles are made off-shore and are pretty much crap. The worst offenders are those for early 90's W-Body coupes with those window pillar handles. Even the OEM ones sucked. The only thing good about them is it's a wrench and screwdriver, 10 minute job to replace.
Most of my cars are +25 years old. Finding decent used OEM handles are getting hard to find.
I've got into the habit of using the outside door handles to just pop the door open and not use it to pull the door open.
I'd rather work under the dashboard than fishing out nut, bolts, linkages and electrical connectors in a door using chopsticks.
Old 08-24-2016, 11:37 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The cheapo replacements eventually led me to just converting to 90s era caddy door handles, very sturdy & solid pieces.
Old 08-25-2016, 06:05 AM
BrianI's Avatar
Have pics of the caddy handles?
Old 08-25-2016, 07:53 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Camaro/bird and others OE handles are still avail. in RIGHT side only.
Old 08-25-2016, 08:43 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old 08-25-2016, 02:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old 08-25-2016, 02:51 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Those Cadillac handles look like Honda handles.
Old 08-25-2016, 03:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Close, theres a few others that look similar as well.
Old 08-26-2016, 07:30 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Why the Caddy handles?
They won't be a direct fit to a camaro/bird door!
Major mods and bodywork involved to fit them...............
Old 08-26-2016, 09:09 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Why not! Not any more (or less) a direct fit then most other upgrades done to these cars.I don't think, any harder than trying to score an original set of door handles that still wouldn't be better designed/built.
Old 08-27-2016, 08:50 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
USE YOUR EYES!
The Caddy handles are a different shape in general than the OE
bird/camaro handles.
Not to mention they lay flat along the surface of the door face in
a Cadillac. (NOTE.......I HAVE a 2011 DTS in my driveway and I
will mention that I have had SEVEN other DTS/Devilles and NONE
of them had/has a door handle similar or a direct no major surgery/
mod fit into a 3rd gen camaro/bird.)
Old 08-27-2016, 11:41 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Well, IM GLAD YOU TOLD ME, never would've noticed that!!
Guess my idea of "major surgery" differs from yours.Id rather spend a weekend redoing these, than sourcing OE door handles.
Old 08-28-2016, 12:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've used Thirdgen Camaro exterior door handles on my 91 S10 Blazer ( and other Blazers ) back when I had that truck & I'm pretty sure it's the same exact part. I've got several factory original Thirdgen door handles just waiting to be re-used. I prefer them to aftermarket versions because the Aftermarket handles seem to "rattle" shortly after they get installed,... but good used handles hold up much better over time.
The one thing I noticed about the aftermarket handles is the VERY POOR quality of the plastic rod "lock". I'm talking about the little plastic retainer that holds the rod in place on the handle. The aftermarket parts are TOTAL CRAP ( usually white in color ) compared to the original rod retainers ( usually black )
After replacing many exterior door handles over the years,..... I'd MUCH rather re-finish a good used handle rather than buying an aftermarket replacement. Aftermarkets parts have a 'better' finish compared to restored parts, but original parts are built & WORK better !!
Old 08-28-2016, 12:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Of the 3-4 times I replaced mine, I used repro's once.After that, OE's from the JY.99% of the time the cheesy wire spring would break or the tiny arms that clamp around said spring would break.You could tell from the looseness/rattles when that happened.
Old 08-28-2016, 12:43 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Many year GMs used the same door handle as the third gen. cam/birds.
My 94 buick has the same handle except its chrome and not black.
NO OEM left side handles for that one either.
Old 08-29-2016, 09:52 PM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
Well I'm doing my body work now and I'm looking to convert my car to C6 door handles
Old 09-06-2016, 07:11 PM
BrianI's Avatar
Removed the 6 month old door handle yesterday. Good quality for sure
Old 09-09-2016, 12:28 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Originally Posted by 84 1LE
Why not!
Because that's the style that's way too easily broken into.
Old 09-13-2016, 07:28 AM
John in RI's Avatar
NOS can be found,.... If your willing to pay for them:
Price:US $225.00
NOS CHEVY CAMARO IROC-Z RS LT 1982 - 1992 BLACK DOOR HANDLE Set + Speed NUT
http://www.ebay.com/itm/NOS-CHEVY-CA...dXrKV~&vxp=mtr
Old 09-15-2016, 10:59 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Guessing this is a long shot, but is there a fix for when the wire "spring" falls out? What is it supposed to be doing in there?
Also, being a GTA, the handles say 'Limited Edition' on them, so any guesses on finding replacements?
Chris Knight
07-14-2020 11:36 AM
MikeCpa
07-05-2016 01:30 PM
Saxondale
06-14-2016 08:24 AM
Jorlain
06-12-2016 06:12 PM
gators_bucs_fan
06-09-2016 12:14 PM
Quick Reply: Replacement outer door handle. Are all the aftermarket handles the same?
