Ram air 2 hood doesnt fit
Old 08-29-2016, 04:03 PM
soarestransam's Avatar
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
(Bought from private seller)
Ok seen tons of post on here about the ram air 2 hood not fitting correctly and im on to take this challenge to make it fit what has everyone done to make it sit lined up with the front bumper so far i have removed the hood stops up front.
From what it looks like when i removed the turn signals to see it comes in contact with the upper radiator support is this hood not made correctly will i have to cut fiberglass out to make it fit ive seen a few cars on google and even hawks firebird and they made it fit correctly.
So people with the ram air 2 hood let me know how u made yours work and have no gaps up front by the bumper
Old 08-30-2016, 12:47 PM
Re: Ram air 2 hood doesnt fit
Bump can anyone help on the fitment for the hood
Old 09-02-2016, 04:34 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
You mean this hood?
Old 09-04-2016, 08:46 AM
Yea this is the same hood i have lol im actually looking at your thread in another tab lol im not trying to pin mine i actually got it to sit alot lower just need to shim the striker down for it to fully hit the latch there is still about a half inch gap though
Old 09-04-2016, 05:11 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
I got an extra pair of hood hinges and enlarged the holes allowing them to slide forward enough to close the gap. Also don't forget not to use the stock steel hood pistons. They are designed for a heavy steel hood and will put too much stress on your fiberglass hood when you close it. I pinned mine because the sides would rise up when going down at highway speeds. I also used a hood spring from an older Buick because the stock hood spring is not bolted to the hood.
http://www.rockauto.com/en/moreinfo....sn=454&jsn=454
A set of these hood pistons are designed for a fiberglass hood. I recommend these as I got the same and they work amazingly well and don't stress the hood when you lift or close it.
Old 09-23-2016, 02:45 PM
Ok bump for everyone kinda got the hood to sit alittle bit better my main concern now is that i stripped out both holes on the passenger side of the hood where it bolts to the hinge i was wondering what i can use to secure it with bolts was wondering if helicoils will work just as fine
Old 09-23-2016, 06:28 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Eh... If yours is like mine than it had steel backing for the bolts. As for using helicoils? Not sure if it would work, but I guess at this point it wouldn't hurt to try. Also I don't think you can put nuts on the back without drilling a hole to reveal the metal backings that were used to secure the hood to the hinge. The hood is a two piece fiberglass. Outer and inner. The inner part covers the steel backing you stripped out.
Old 09-24-2016, 07:53 AM
Yea dont think it has a metal insert in the fiberglass looked in the hole and didnt see threads so I think they threaded threads into the fiberglass but i guess if u go to tight it pulls those threads out so how do i go about installing the inserts
Old 09-24-2016, 08:08 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Ty can tell it has the metal inserts but the two rivets holding it to the fiberglass. Well at least the one I got had them. Also o don't think helicoil would work on fiberglass. My suggestion? Where the holes where that you stripped out. Get a piece of metal for backing drill a hole in it and tap it (if you want otherwise just have a bolt for the back) That what you can have a backing. Also.... Can we see pictures of the locations of holes used for mounting the hood to the car?
THIRDGEN87
Interior Parts Wanted
08-24-2023 01:01 PM
dmorse1
Exterior Parts for Sale
04-27-2016 10:13 AM
Brian28166
03-30-2016 03:09 PM
turbochicken
03-30-2016 08:08 AM
Veaceonee
03-15-2016 01:45 PM
Quick Reply: Ram air 2 hood doesnt fit
