Felt
Felt
OK so got a 1987 Camaro with t tops. I've searched and searched and cannot find anywhere that talks about the felt strips that run in the t top center bar. I assume they are so the top of glass has cusion instead of glass to metal. I started taking mine apart to clean up and replace seals and noticed it was shot as I was cleaning crap off center bar. Does anyone have a part number or link to the felt strips for center bar or a suitable replacement? I was lucky and only had some minor surface rust on one part that started pitting. Going to clean it all up, smooth it with Bondo, paint and re install everything. Thanks in advance.
Re: Felt
Oh and also the channel pieces inside door jam on back are missing. The pieces that the t top weatherstripping clips in. Can't find any replacements for those either.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Felt
No felt,top lays on the rubber weatherstripping.You might need new T Top Weatherstripping
http://www.classicindustries.com/pro.../10164133.html
Re: Felt
Engine: 5.0 EFI
Re: Felt
No,the top doesn't have a edge,only the front where you latch it, the top should be bare
Show a pic of what you mean.
Re: Felt
Where the glass slides under the center bar there. It's just glass on metal then? Maybe previous owner installed felt to try to stop leaking I don't know. Looked like they used liquid nails as well on part of seal lol. This car was a hack job. Lotsss of things to fix.
Re: Felt
The early glass t-tops, had a thin steel frame around the glass, and the lexan t-tops have a sorta frame on the front and back edges. Certain diagrams might show those details, of course artists renditions are always a bit suspect. Anyway, there shouldn't be anything there except the weatherstripping.
