dumb bleeding question.
Old 12-10-2007, 11:49 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I just threw in my moser rear and replaced the rear line. Now when I bleed it do i have to bleed the fronts too?
Also I should do the RR first then LR right?
Just making sure last time i bleed brakes I had to do them all because i changed everything (damn fords)
Jay
Old 12-10-2007, 11:58 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: dumb bleeding question.
If you break a brake line anywhere in your system it is always a good idea to blead everything. It really doesn't matter on the which side you bleed 1st as far as left or right. A good rule of thumb is always start with the farthest point away and bleed to the closest. So, yes do the backs 1st then the fronts.
Old 12-10-2007, 01:03 PM
TA
TA's Avatar
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
On a system with dual master cylinder reservoirs, the front and rear systems are separated for safety, thus if one fails, you have the other system intact.
IBMtech is right on, start with the furthest and work to the brake nearest the master cylinder. Technically, you should not have to re-bleed the fronts, but I would very much encourage you to do it anyway, because the seals in the master cylinder are VERY close together, you might have pushed some air into the front system. Better safe than
TA
ZZ3Astro
08-13-2019 12:57 AM
corey8084
09-17-2015 02:56 PM
Rally Smith
09-14-2015 06:59 PM
dimented24x7
09-06-2015 03:51 PM
Ian Irvine
09-04-2015 08:08 AM
Quick Reply: dumb bleeding question.
