C5 Wheels And Big Brakes
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Is anyone using OEM C5 wheels on their 3rd gen? I want to use the largest rotor and caliper that will fit. 17's front 18's rear. Doing a search I couldn't find anything.
1 Post
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: C5 Wheels And Big Brakes
Ya same boat dude. I couldn't find a guide on big brake do-it-yourself guides either. Maybe someone else will give us a link..
1 Post
Car: 1987 Iroc-z Convertible
This was hard to find
https://www.thirdgen.org/forums/brak...l-fitment.html
very first thing in the stickies on the brake board if you can't find the combo on here then PM e-mail or call ed miller on here. I am pretty sure it is on the sticky somewhere but can't gaurantee it.
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Car: '91 TA vert
Engine: turboLSx
Ebmiller has a kit that uses a z06 14" rotor and standard c5 caliper. That MAY fit but I doubt it. That's about your only option. If you want 14" rotors just pick up two sets of c5 wheels and run rears all around. That's what I did.
CTS-V Brembos will fit under a 17" wagon wheel using a c6 z51 13.4" rotor though. And the new Camaro's Brembos look like they have the same lug mounting points as a -V caliper so you may be able to get a brembo that says chevrolet and be CHEAP (Like $100/per caliper cheap).
I had c5 13" under the 17s and 14" c6 z06 under the 18s.
1992rs/ss
16
01-28-2016 09:58 PM
