PRB rear brake caliper Counter Weights...
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I have a question about the PBR rear brake counter weights, mainly what do they do exactly. I have two different sets of PBR calipers one with the counter weights and one with. The set with the counter weights the rubber bushings are warn out so I was wondering what if they can be replaced and what purpose if any do they serve or do they not matter really all that much.
Any input on this would be great, thank you in advance.
Kevin
Kevin
Re: PRB rear brake caliper Counter Weights...
JamesC
Engine: L98 350 TPI
Thanks! I guess the calipers that I have were not the original ones to begin with. That helps me out a ton!
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Trash them, no need and they're just added weight.
Ed
Ed
Engine: L98 350 TPI
Thanks Ed.
Eric-86sc
04-03-2016 03:52 PM
sailtexas186548
01-19-2016 12:21 PM
