J65 BRAKES
Old 06-20-2009, 09:47 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
J65 BRAKES
my iroc has the rpo code j65 brakes. the fronts have a single piston caliper setup, the rear are pbr aluminum calipers. i need to repair the front brakes. the parts guy at o'reillys said the car came with dual piston alum calipers and i should upgrade to these. if i buy these will they fit. the remans are cardone 18-4343/44 and it includes hardware. so is this a easy swap and repair job.
Old 06-20-2009, 10:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Re: J65 BRAKES
You have to modify the spindle, buy 1LE rotors, and more. Here is a 1LE brake upgrade how-to: http://www.ws6transam.org/1LEbrake.html
If you want to go the brake upgrade route you may want to consider some other options link C4, LS1 brakes.
Old 06-20-2009, 10:33 PM
marine68's Avatar
Car: 89 IROC Z28
Re: J65 BRAKES
thanks for the info, did your iroc come with the australian pbr brakes in the rear when you bought it.
Old 06-20-2009, 10:45 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Re: J65 BRAKES
My car came with 11.67" rear with PBR aluminum calipers and 10.50" front with single piston iron caliper. I upgraded to C4 HD 13-inch front brakes. If you are interested in doing so click the link in my signature to my website, I have a full how-to there.
Old 06-20-2009, 10:51 PM
marine68's Avatar
Car: 89 IROC Z28
Re: J65 BRAKES
thanks, i already read your site and it is professionally done. so the auto parts guy is wrong then, i can't install the pbr front calipers without these mods. he did not mention the car needed a 1LE RPO to use these brakes. i guess i'll have to replace the regular calipers then.
Old 06-21-2009, 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: J65 BRAKES
Unless your car was originally equipped with 1LE fronts, the standard four-wheel disc set-up is Delco-Moraine, single-piston, iron calipers with 10.5" front rotors and PBR, single-piston, alum calipers with 11.7" rear rotors. And, yes, the auto parts fellow is wrong. BTW, all 82-92 four-wheel disc cars are RPO J65, regardless of caliper type or rotor size.
JamesC
BADNBLK
Convertibles
09-21-2015 07:56 PM
dbrochard
09-19-2015 08:13 PM
Necron
Brakes
09-14-2015 12:45 PM
Buickstaged
Brakes
09-04-2015 07:53 AM
1Aauto
Sponsored Vendors
09-02-2015 01:50 PM
Quick Reply: J65 BRAKES
