9 bolt disc brakes swap - Third Generation F-Body Message Boards
Sponsored by Manual Brake Kits
Click Here
Thread Tools Search this Thread
Old 08-30-2009, 04:44 AM   #1
Car: 1988 Camaro Iroc Z28
Engine: 5.7L TPI
Transmission: 700R
Axle/Gears: 4 Wheel Disc/ 2.77 Borg- Warner Pos
OK Guys... I need help please. I have a 88 Iroc with the Borg-Warner axle with disc brakes. Can i swap the disc brakes from the 9 bolt to 2004 10 bolt exle???
My Borg-Warner rear axle is makeing a woring noise when driveing. I have checked the gear oil to find the oil was leaking out and had a very small amount of oil left in it. So i fix the leak and put in new oil plus the additive for Possy track rear ends.
I just got the car and fixing the bugs out of it. The 10 bolt rear end was bought from F-Bodys in Charrlott, NC. I believe they told me the 10 bolt was out of a 2004 Formla Firebid, but it haves the DRUM BRAKES.
So I thought to go ahead and swap rear ends out and put the disc brakes on. Am I makeing the right choise??????
Also... what is so specail about the Borg Warner rear ends?????
cars44tars is offline vBGarage Page   Reply With Quote
Old 08-30-2009, 07:52 AM   #2
JamesC's Avatar
Car: Met. Silver 85 IROC
Transmission: T-5 (Non-WC)
Re: 9 bolt disc brakes swap
Welcome to TGO.
You can't swap the disc to a drum rear without modification or Ed Miller's kit. Remember too that you'll need a disc proportioning valve, e-brake cables, and driven and/or driven gears to make the speedo rear correctly.
BTW, the flanges/backing plates are different between 9- and 10-bolts. Nine-bolt are a bit stronger, but parts are apparently difficult to come by. The following FAQ will provide more info on 10-bolts:
http://www.thirdgen.org/techboard/tr...-10-bolts.html
JamesC
JamesC is offline vBGarage Page   Reply With Quote
Old 08-30-2009, 05:41 PM   #3
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Also the 4th gen rear is wider (but it will bolt in). Sounds like your 9 bolt needs a bearing kit. Might be easier in the long run to fix it.
jv9999 is offline vBGarage Page   Reply With Quote
Old 09-01-2009, 02:53 AM   #4
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Quote:
Originally Posted by JamesC View Post
BTW, the flanges/backing plates are between 9- and 10-bolts. Nine-bolt are a bit stronger, but parts are apparently difficult to come by.
Can you explain this a little better? Im not sure what you mean.
InfernalVortex is offline vBGarage Page   Reply With Quote
Old 09-01-2009, 07:50 AM   #5
JamesC's Avatar
Quote:
Oops, my bad. Nine- and ten-bolt backing plates aren't interchangeable; the bolt pattern is different.
JamesC
Thread Thread Starter Forum Replies Last Post
SOLD Iron Caliper Delco Moraine Disc Brake Backing Plates sailtexas186548 Engine/Drivetrain/Suspension Parts for Sale 8 01-19-2016 01:21 PM
[MI] 10 Bolt Rear End Package Deal hectre13 Engine/Drivetrain/Suspension Parts for Sale 1 12-27-2015 09:30 PM
[TN] FS 1992 CHP EVOC B4c/1LE Camaro Vintageracer Camaros for Sale 8 10-21-2015 11:26 PM
burnouts with a factory locker.. is this normal? novaderrik Transmissions and Drivetrain 3 08-10-2015 01:44 PM
[CA] Complete Parts Car- For T56 & LT1 Transplant to a Third Gen!!!! THIS WEEKEND ONLY 1992 Trans Am Engine/Drivetrain/Suspension Parts for Sale 1 08-08-2015 09:16 PM
Go Back   Third Generation F-Body Message Boards >
Tags
1988, 84, axle, bearing, bolt, borg, brakes, camaro, disc, end, gears, irocz28, rear, warner, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
