9 bolt rear end with disc brakes what proportioning valve? - Third Generation F-Body Message Boards
Sponsored by Manual Brake Kits
Click Here
Thread Tools Search this Thread
Old 03-08-2010, 11:15 PM   #1
i just swapped out my 10 bolt with drums for a 9 bolt with disc brakes, what proportioning valve should i go with? ive been looking at the adjustable ones but is there a stock one that would work? or is an adjustable one a better option?
goes12s is offline vBGarage Page   Reply With Quote
Old 03-08-2010, 11:22 PM   #2
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: 9 bolt rear end with disc brakes what proportioning valve?
Are you done with the swap? Do your brakes work now?
1brd2brd3brd4 is offline vBGarage Page   Reply With Quote
Old 03-09-2010, 07:26 AM   #3
JamesC's Avatar
Car: Met. Silver 85 IROC
Transmission: T-5 (Non-WC)
Quote:
Originally Posted by goes12s View Post
i just swapped out my 10 bolt with drums for a 9 bolt with disc brakes, what proportioning valve should i go with? ...is there a stock one that would work?
Yes. But we need more info about the year of your car and what type of brakes the 9-bolt has (iron Delco-Moraine or alum PBR's).
The following is about 10-bolts but the brake info (toward the bottom) is the same as for the 9:
http://www.thirdgen.org/techboard/tr...-10-bolts.html
JamesC
JamesC is offline vBGarage Page   Reply With Quote
Old 03-09-2010, 10:14 AM   #4
well what happened is this, i had a rebuilt 10 bolt with 3.73 gears and my brother had this rebuilt 9 bolt with 3.45. I went with a turbo so i wanted lower gears and he wanted my 3.73s so it worked out great for me. On his thirdgen which came factory with drums, the rear brakes werent good, its like they werent getting enough pressure. I belive everything is stock like new stock rotors, new calipers and new pads.
My car had great brakes with the drums and i wouldnt want disk brakes to be a "downgrade" lol
Old 03-09-2010, 11:04 AM   #5
JamesC's Avatar
Use the correct combination valve as noted in the link above and you should be good to go. You might take note of the speedo drive and/or driven gears as well as the parking brake cables.
JamesC
Old 03-09-2010, 12:58 PM   #6
so just to make sure, my car is a 89 trans am, if i get a 89 1LE proportioning valve i should be all good to go? and should i also get 1LE parking brake cables? or will the stock drum cables work? i didnt quite understand that part. THanks for all the help
Old 03-09-2010, 02:37 PM   #7
JamesC's Avatar
Does the 9-bolt have alum (PBR) calipers? If you're unsure of what those are, check my vBgarage on the lower left for pics. If the above is what you have, you need the J65 (the RPO for 4-wheel disc brakes) 1LE combination valve, first design, along with first design rear disc parking brake cables.
If you have iron Delco-Moraine calipers, you'll need the mid-eighties J65 combination valve and mid-eighties rear disc parking brake cables.
I'm assuming you have the tunnel-mounted parking brake adjustment feature in you car.
JamesC
Old 03-10-2010, 10:40 PM   #8
they dont seem like aluminum to me this is what they look like
are these the brake cables i would need for this application?? thanks for all your help JamesC
http://cgi.ebay.com/ebaymotors/88-89...item5ad344ff43
Old 03-11-2010, 12:43 AM   #9
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I used a Summit adjustable valve when I converted to disk's. I can now make the brakes feel the way I want. By the way, you may think that your car will stop the best with the pressure turned all the way up, but thats not the case. About midway is where the car stops the best. Heres a pic of where I put it. Its real easy to just reach under the car and adjust it. No need to jack the car up.
(pay no attention to the ugly exhaust. Its off the car and the new exhaust starts going on tomorrow.)
built91Z28 is offline vBGarage Page   Reply With Quote
Old 03-11-2010, 07:44 AM   #10
JamesC's Avatar
they dont seem like aluminum to me this is what they look like...
Those are the iron Delco-Moraine, 82-88. Since the advertisement is for 88-90, I suggest the cables are for the alum PBR's, 89-92.
JamesC
Old 03-11-2010, 10:23 AM   #11
i like the idea of the adjustable proportioning valve but i would have to put it in the factory location and im sure the threads will be dif. than factory. I think it might be easier to get the 1le proportioning valve that will be a direct fitment
Since those are standard brakes, and not the so-called 1LE's (PBR's), I recommend the standard J65 valve, post #7.
JamesC
Old 03-11-2010, 10:47 AM   #12
JamesC's Avatar
JamesC
Goes, sorry, I inadvertently edited your post by inserting my reply.
Old 03-11-2010, 03:37 PM   #13
haha i was wondering what happened to my post. lol Thanks for all your help that really helped me out alot.
Old 03-19-2010, 06:30 PM   #14
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
rather than reposting a new post I have a similar question to the one posted. It's just hard with all the different brake lines, master cylinders, and prop valves combinations for every year. I tried reading through many posts and spent several hours trying to find my answers.
I have an 85 z28 that i swapped out my broken 10 bolt drum brakes for a 9 bolt disc brakes with i believe the PBR brakes. i just want a straight answer if anyone could be so kind to help about what needs to get replace from my stock M/C, prop valve to get my rear brakes working a little better than normal. or does the master cylinder even need to get replaced or is it just the prop valve.
n8sz28 is offline vBGarage Page   Reply With Quote
Old 03-19-2010, 06:56 PM   #15
JamesC's Avatar
Quote:
Your master is fine. You'll need to change the combination valve to the first design 1LE, which you can purchase from the following site:
http://www.flynbye.com/catalog/i40.html
JamesC
Old 03-20-2010, 06:29 PM   #16
Car: 85 camaro z28
alright thanks a lot should all the brake lines and from the M/C to prop valve to other brake lines match up properly with the part?
Old 03-20-2010, 06:36 PM   #17
JamesC's Avatar
Yes, bolt up--was on my 85.
JamesC
Thread Thread Starter Forum Replies Last Post
SOLD Iron Caliper Delco Moraine Disc Brake Backing Plates sailtexas186548 Engine/Drivetrain/Suspension Parts for Sale 8 01-19-2016 01:21 PM
[MI] 10 Bolt Rear End Package Deal hectre13 Engine/Drivetrain/Suspension Parts for Sale 1 12-27-2015 09:30 PM
[TN] FS 1992 CHP EVOC B4c/1LE Camaro Vintageracer Camaros for Sale 8 10-21-2015 11:26 PM
[MI] Never Used Posi and Gears for sale hectre13 Engine/Drivetrain/Suspension Parts for Sale 7 08-26-2015 09:17 AM
[CA] Complete Parts Car- For T56 & LT1 Transplant to a Third Gen!!!! THIS WEEKEND ONLY 1992 Trans Am Engine/Drivetrain/Suspension Parts for Sale 1 08-08-2015 09:16 PM
Go Back   Third Generation F-Body Message Boards >
Tags
1le, 3rd, bolt, brake, camaro, disc, drum, end, ends, gen, proportioning, rear, swap, swapping, types, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
