Cheap Proportioning Valve Upgrade
#201
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Cheap Proportioning Valve Upgrade
83-88 cars had delco calipers that had to be rotated to compress.
http://www.tooltopia.com/lisle-41000...ricegrabber_r1
-- Joe
-- Joe
#202
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Originally Posted by*TallTim*I'm in for a 1NCR5 19 lb spring, kinda lost track who had em avail here...*If anyone has one you can spare to sell!?
^what he said, looking for a 19lb
Ill take a 22lbr too
#206
Car: 88 GTA Notchback
Axle/Gears: don't know
I have 3 1NCR5 springs left over from when I did mine. PM me if interest.
Don't ask me if it actually worked because i can't tell you. when I went to bleed my rear brakes it reminded me of when I play Basketball- nothing but air. They do work alot better now however.
#207
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Just a quick question. When you unscrew the bolt to get at the original spring, does brake fluid squirt out? Or does the reservoir have to be empty before you unscrew it?
#208
I had a couple drops come out. nothing to write home about. Put a rag under it.
#209
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
Yes make sure you have plenty of rags when you unscrew it brake fluid will mess up your paint
#212
its better to be prepared I always use 3 rags brake can ruin a great paint job
#214
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
Anyone have a 1NCR5 to sell ??? pm if so thanks
#215
1 Post
Car: Iroc-Z
Engine: TPI 305
Just swapped to LT1 rear brakes, got the internal from the disk proportioning valve and installed on my drum proportioning valve and it worked perfect.
#217
I just read through this but I want to know - has anyone actually tried this on the older 82-83 combination valve? I am installing a new MC this week and I wanted to give this a shot. Just wondering if the spring and spring pressures are the same.
#218
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
hey guys, i don't know if anyone is still interested but i have (4) 1NCR5 springs. PM if interested. my zip is 07094 if you want to look up shipping.
#219
For sale:
two 1NCF2 springs
$3 each, + $2 shipping for as many springs as you want in a padded envelope. Shipping to 48 states only. PM me.
1NCR5 springs are all gone...
two 1NCF2 springs
#220
I just did this mod to my 82 TA with the Kelsey Hayes proportioning valve. I am not sure I like the results. It is raining here so I couldn't really give a good test, but the backs seem to lock before the front at times. When I took the spring out I noticed the original was about 1/4 inch shorter. I am not sure if this made a difference, but It might have less room to move. I may take it apart and trim the spring a bit to see if it makes a difference.
#221
stock - 39.8mm
1NCR5 - 37.52mm
1NCF2 - 38.02mm
I never tried the 1NCF2, but with the 1NCR5 I am not able to lock front or rear brakes. I'm quite pleased with the results.
#223
#227
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
Zoro tools is another good source for these. Pack of 5 $4.65 + about $5.00 shipping.
Link to 1NCR5
http://www.zorotools.com/g/00056855/k-G0463723
Link to 1NCF2
Link to 1NCR5
Link to 1NCF2
#228
#229
Car: 89 Iroc
Engine: 5.0L
i have the same spec spring but in a 32lb instead of 30lb..what will it do?
#230
Car: 1988 Pontiac gta
Engine: 5.7 tpi
Axle/Gears: Borg Warner 3.27
I just got my springs in today and I stalled it and bled the rear brakes and wow instant gratification
This post should be stickied
#231
Engine: 5.7 tpi
i did this small upgrade and very shocked on the large amount of difference from a small spring
#232
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
I'd like a 19lb spring.
I'm assuming it'll work in a 87, never saw that it wouldn't in The thread
#235
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
This is what I did. It may not be for everyone but it's a compromise between stock and the 19# spring.
First a little background. My car is an 89 IROC (late 6/89 car- 2 design) with the "performance/1LE" J65 rear disc brakes~ 11.6 rotors/PBR calipers. I have upgraded the front to stock LS1 with ceramic pads and stainless lines. My proportioning valve is stock for this model. The rear calipers were gone through with new rotors and semi-metallic pads. Like others I felt the rears could do more but didn't want a rear lock up issue as this is a street driven car. BTW I have a good parking brake.
I used the brass banjo washers used on the caliper hoses to shim my stock spring. I picked up an assortment at the local auto parts store. The ID (.380") of the washers are correct but the OD needed trimming down to .510". I scribed a line around the washer with my dial calipers and ground the majority on my bench grinder. The final few thousands I took off with some 220 & 400 paper wetted with WD40.
I used an .032" washer on the end of the spring where it touches the valve and an .062" on the plug end for a total of ~.094" shim. This dimension was used because it basically was the most I could put in each position and still have enough pilot to center the spring well.
The only feedback I can give is that it feels better. I have great brakes with this setup but the rears don't lock up in the wet. My goal was to not over-bias the rears. However, with the larger LS front piston area I felt the rears needed a bit more bias & this is a compromise between stock and the 19# spring.
#236
Engine: 350 tpi
Hey guys I just ordered a pack of the 1ncr5 19lb springs ill have 4 left after mine, anyone need some?
#239
Engine: 350 tpi
#242
Engine: 350 tpi
2 19lb springs left if you want them pm me. It easier for me to keep track that way.
#243
Well I just got done swapping this spring in (Thanks 396lsx!) and to be honest I don't feel a major improvement over stock. I'll say that the rears to feel a little more active but not the big change I was expecting. Still not a bad upgrade for a few bucks.
#244
On mine there was a big deference in the back which is where there a big change for the better happy with mine
#247
1 Post
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Does anyone have one that I can buy? pm me please and I can send paypal thanks
