Proportioning Valves - Third Generation F-Body Message Boards
Sponsored by Manual Brake Kits
Click Here
Thread Tools Search this Thread
Old 01-23-2011, 07:52 PM   #1
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
I have a 3rd Gen Proportioning Valve off of a 1985 Firebird with Disc Brakes. It's rear was a Borg-Warner. I'm going to use a Rear out of a 4th gen and the disc brakes are larger. Could i use the Valve out of the 85, or do i have to purchase a special valve? My Car is a 1982.
Since i'm Replacing all of the Brake Lines, Cables, and Calipers, should i also replace the Dampeners, or are those a non-wearing item?
383 Power is offline vBGarage Page   Reply With Quote
Old 01-23-2011, 08:15 PM   #2
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Proportioning Valves
Some of the earlier models had different threading on the lines going to the proportioning valve. Coincidently, I do have one of the earlier model cast iron valves if you need to find one.
chevysquid is offline vBGarage Page   Reply With Quote
Old 01-23-2011, 08:18 PM   #3
383 Power's Avatar
No, i have the early version for disc brakes, but i didn't know if it would work with 1994 Disc Brakes.
Thank you for the offer though
Old 01-23-2011, 08:39 PM   #4
I think it was that the earlier ones were SAE threaded and everything else after is metric. From what I've read either one would work though.
Old 01-23-2011, 09:37 PM   #5
JamesC's Avatar
Car: Met. Silver 85 IROC
Transmission: T-5 (Non-WC)
I discussed some of this with you in the thread to follow:
http://www.thirdgen.org/techboard/su...list-find.html
To perhaps better clarify: As I understand it, the following valves increase in bias from first to last:
Disc/drum
Disc/disc (10.5" rotors with Delco-Moraine calipers)
Disc/disc (11.7" rotor with PBR's, the so-called 1LE, or in your case the LT1, 93-97)
So you need either a 1LE combination valve or an adjustable for best braking performance.
Check the following link for more about master cylinders, combination valves, speedo gears and parking break cables (the braking systems are the same for the 9- and 10-bolt):
http://www.thirdgen.org/techboard/tr...-10-bolts.html
JamesC
JamesC is offline vBGarage Page   Reply With Quote
Old 01-24-2011, 12:25 AM   #6
383 Power's Avatar
Thank you! THAT was the information that i was seeking. I'm sorry to ask so many questions, but since i've never done anything like this before, I want to leave nothing to chance. The more i do, the more questions i have, and you guys are a wonderful resource to tap. I have to say that I'm not looking forward to plumbing in a new Proportioning valve. I would just get the 4th Gen's Master Cylinder too, but i guess the hoses running from the body would be a different size too. There just seems to be no way around this. I was planning on making the swap on Thursday. It seems i'll have to delay until next week.
Old 01-24-2011, 01:02 AM   #7
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
James, you are a true benefit to the Forum. Your knowledge base, research, and support to the site is greatly appreciated.
Ed Miller
ebmiller88 is offline vBGarage Page   Reply With Quote
Old 01-24-2011, 01:09 AM   #8
383 Power's Avatar
Quote:
Ed Miller
Agreed......... The Link was AWESOME! This is making me feel better about this swap. He's done it now though. I'll probably bug the hell out of the guy from now on. I'll try not to be too much of a Pain though.
Old 01-24-2011, 01:19 AM   #9
383 Power's Avatar
Here is the Valve i Ordered:
http://www.summitracing.com/parts/WIL-260-11179/
It has 2 Inlets, and 3 Outlets just like the original. It even looks like it will fit on the bracket the same way and the threads appear to be SAE.
Thread Thread Starter Forum Replies Last Post
Which proportioning valve 84 Z28 with LS1 Rear? SPEEDY Z28 Brakes 16 04-18-2016 03:46 PM
catch can picts. sleprock Power Adders 9 09-24-2015 05:33 PM
700r4 locked into 1st HikoriYami Transmissions and Drivetrain 2 09-21-2015 08:11 PM
AFR heads and cast gm valve covers.... Need VC stud kit 355tpipickup Tech / General Engine 9 09-14-2015 12:35 AM
Spring locators for vortec head? sandman92084 Tech / General Engine 13 09-12-2015 11:27 PM
Go Back   Third Generation F-Body Message Boards >
Tags
3rd, brake, brakes, camaro, difference, disc, drum, gen, generation, ls, poportioning, porportioning, proportion, proportioning, propotioning, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
