which proportining valve for my car help
Old 05-05-2011, 09:07 AM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
i have a 92 rs with drum rear and im swaping in a 88 iroc rear with disc should i use the proportion valve from the 88 or buy a valve for a 92 with disc /disc
Old 05-05-2011, 08:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: which proportining valve for my car help
the fitting sizes on the valves changed somewhere in the late 80's, get a 92 one to be safe
Old 05-05-2011, 08:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 88 combination valve, which is correct for the rear in question, won't fit the threads of your 92, and the 90-92 disc valve is for PBR's (11.7" rotors and single-piston alum calipers). I'm unsure of how the increased bias of the latter might affect braking. And as you may recall, there's an parking brake cable problem as well. If you could locate one, the 89-92 (or even a fourthgen rear) disc brake rear end would eliminate the above problems.
A gander through the 10-Bolt FAQ may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old 05-06-2011, 03:40 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
I have done the same swap on my 92 z28. I used the 90 - 92 valve from a 4 wheel disc car. I can suggest 2 things to do on this swap.
1 get a GM PN 18019028 Caliper, repair kit from gm parts direct or flynbye
2 do some reading about the calipers on this site there is alot of info about them on this site good and bad
1992 Trans Am
05-10-2023 07:19 PM
NBrehm
08-25-2015 11:49 PM
89mulletbird
08-12-2015 07:08 PM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
mustangman65_79
08-08-2015 01:18 AM
Quick Reply: which proportining valve for my car help
