how do i get rear caliper piston back?
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i used an allen wrench like guy at garage said but with that thing attached to it (dont know what to call it) hows it suppose to turn? it did start to turn once but made wierd noise so i stopped b4 i broke something.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: how do i get rear caliper piston back?
idk what pbr means. but yes its a 91 formula.
Car: 85 IROC Z
Axle/Gears: stock ratio
if you fixed your issue then disreguard, just did my brakes yesterday and had the same issue, how ever I researched it in a book and apparently you need to put a brake tool (to compress the piston in) while in place remove the parking brake lever then the piston will compress in, after it is in enough for you, put the parking brake lever about 1/8 inch from the stop on the caliper, and you should be good.
Eric-86sc
04-03-2016 03:52 PM
sailtexas186548
01-19-2016 12:21 PM
