replaced booster
Old 07-15-2011, 10:06 PM
c10chas's Avatar
Car: 85 Iroc
Engine: LB9
replaced booster
I just replaced the MC/Booster on an 85 Iroc with one from a 1990 I found on Ebay, is it normal to hear that air whooshing noise when pressing down on the brake pedal?
Old 07-15-2011, 10:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: replaced booster
it will make some noise, yes
Old 07-16-2011, 11:49 AM
c10chas's Avatar
Car: 85 Iroc
Engine: LB9
seams loud from what i remember of this vintage
Old 07-16-2011, 12:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by c10chas
seems loud from what i remember of this vintage
The packing may be missing from the area where the pedal rod enters the booster. This is both an air filter and silencer. I've been known to reduce the amount of packing for a quicker brake response.
RBob.
Old 07-16-2011, 06:05 PM
c10chas's Avatar
Car: 85 Iroc
Engine: LB9
Bob, what should I expect to see (looking from under dash) for packing? Is it visible?
Old 07-17-2011, 02:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm not sure what it is on our 3rd gens. The older cars GM used a jute packing, same material that is used under the carpets.
Although, the '92 FSM shows a plastic or rubber boot. Then further into the booster the silencer, which looks like a big jute or felt washer in the diagram.
RBob.
cstrobel65
08-15-2015 10:19 AM
pigpete
Exterior Parts Wanted
08-15-2015 07:56 AM
Dan Hubbard
08-12-2015 09:05 PM
MustangEater82
Brakes
08-11-2015 07:52 AM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: replaced booster
