proportioning valve sensor? - Third Generation F-Body Message Boards
Sponsored by Manual Brake Kits
Click Here
Thread Tools Search this Thread
Old 07-17-2011, 01:21 PM   #1
have a odd problem, i've not come across before with my brakes. there's a sensor in the proportioning valve, if I connect the wire to it, my brake light comes on instantly. new calipers, new hoses, new rotors, new pads all around. flushed and changed brake fluid. I drive a 89 trans am GTA 5.7L with four wheel disc brakes. the car does not have the 1le option. There are no leaks, and the only physical trouble I can tell is at highway speeds if I brake hard the car wants to pull to the left. Any ideas?
phlipdawg is offline vBGarage Page   Reply With Quote
Old 07-17-2011, 01:44 PM   #2
JamesC's Avatar
Car: Met. Silver 85 IROC
Transmission: T-5 (Non-WC)
Re: proportioning valve sensor?
Quote:
From the manual:
"The pressure differential warning switch is designed to constantly compare front and rear brake pressure from the master cylinder and energize the warning light on the dash in the event of a front or rear system failure. The valve and switch are so designed that the switch will latch in the "warning" position once a failure has occurred. The only way the light can be turned off is to repair the failure and apply a pedal force to develop approximately 450 psi line pressure."
Pulling usually indicates a flex hose problem
JamesC
JamesC is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
1992 camaro 305 v8 TBI idles very high and shifts at high idles db057 TBI 11 06-07-2016 09:26 PM
[WY] Rocker Stud Girdle For Sale New2Chevy Engine/Drivetrain/Suspension Parts for Sale 2 09-28-2015 01:35 AM
JTR VSS HELP!!! GTAman Transmissions and Drivetrain 15 09-14-2015 10:53 AM
Timing fluctuation db057 TBI 13 09-04-2015 08:57 AM
[PA] 1985 Award Winning Modified Pontiac T/A Hotrodboba400 Firebirds for Sale 0 09-02-2015 08:28 PM
Go Back   Third Generation F-Body Message Boards >
Tags
1988, brake, brakes, caliper, cj7, connect, fluid, gen, lights, portioning, proportioning, sensor, switch, trans, valve, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
