drum to rear... but different probs inside
Old 11-20-2011, 03:41 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
ok. had it installed and never checked the work. been sitting for a yr. now that i have looked, the installed snipped the drum e brake lines but the disc didnt come with any.. suggestions? also he snipped the brake rear lines front the drum rear... but the disc lines were also snipped.. any suggestions? also my car is a 88. rear came from ??. how would i know if i need a proportion valve? i looked at the thread ones suggest but still didnt see it posted exacty.
Old 11-20-2011, 06:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: drum to rear... but different probs inside
I had a difficult time deciphering the above, so I'll guess. If the rear is an 82-88, it'll have 10.5" rotors and iron Delco-Moraine calipers. Buy parking brake cables for your 88. Buy an 84-88 disc combination valve (make sure that it'll alum and not cast iron). If the rear is 89+, it'll have 11.7" rotors and alum PBR calipers. Buy the first-design parking brake cables (1434 mm). Buy the first-design 1LE combination valve.
JamesC
Old 11-20-2011, 08:19 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
ok. they have the 10.5 rotors.. do you happen to know a part number on the valve? and what about the brake lines?
Old 11-20-2011, 08:44 PM
JamesC's Avatar
No part number offhand. I'd hit one of the pick and pulls in the area and yank one off a rear disc car (84-88) or advertise in our classifieds and/or CL. Several after market companies fab brakes lines:
http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Linson
09-25-2021 07:55 PM
92projectcamaro
12-08-2015 12:25 AM
Bubbajones_ya
10-25-2015 08:01 PM
KO1
16
10-15-2015 05:00 PM
BrianChevy
Wheels and Tires
10-13-2015 12:33 PM
Quick Reply: drum to rear... but different probs inside
