I said STOP !!
Car: 87' IROC
Re: I said STOP !!
Hmmm, strange. Looks like you have retained the original 10.5" rotor? If so I can't see much purpose in this swap. Care you share what you goal is?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: I said STOP !!
That looks like a 1le rotor and 1le or c4 caliper
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Re: I said STOP !!
I didn't know the 1LE had cross drilled rotors
Re: I said STOP !!
Thanks for the interest in my new brake system .. This is a Baer brake track pac C4 caliper with SSBC 1le adapter brackets and 1le abutments all powder coated. The rotors are made by ERP out of Canada I also am installing braided steel flex hoses .
this is to go with my 1le Pbr brakes that I all ready have out back.. I have been piecing this system together for years first got the calipers in 2007 !! About time I replace the 20 year old original 10.5 front brake system with something shall I say more substantial
if you are observant you will notice the I have the rotor on the wrong side of the car..... don't worry this is only the mock up test fitting of components ..
sjorgens
10-01-2015 07:54 PM
