Help finding a 9/16" female fitting
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Does anyone know where to find a female 9/16" inverted flare fitting? Common size in male, but impossible to track down in female
This is for an older car, mating a common 3/16" line to a factory 9/16" fitting where the prop valve used to go
The line is 40 years old so I wouldn't trust a reflared fitting in a more common size. Definately won't trust a compression fitting
If I can't find an adapter fitting, I'll have to replace the line all the way back to the rear tee
Anyone got an idea?
Anyone got an idea?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Help finding a 9/16" female fitting
http://m.summitracing.com/parts/edd-127031
would u be able to make something like this work?
Car: 92 Firebird
Got these so far
EDD-258306
EDD-258350
AAF-ALL50132
9/16 female to 1/2 male
1/2 male to 3/8 female
1/2 union
This is to finish out a wilwood brake upgrade on a c3. Kit has everything else, just not this fitting. Irritating
EDD-258306
EDD-258350
AAF-ALL50132
1/2 union
Car: 1988 Camaro
Try looking at 'the chassis shop'. They seem to have all sorts of odd fittings. Only place I could find the ISO metric bubble to SAE brake line adapter fittings when I installed a link lock in my camaro
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
