99 blazer disc to 86 camaro
Car: 86 Z28
Engine: 67 327cu. dart II heads
Transmission: 700R4 2200 stall
Axle/Gears: 3.73 gears
I have a 10 bolt from a 99s10 blazer with disc brakes. And i wanna switch the disc brakes off of it to my 10 bolt in my 86 camaro will they fit
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 99 blazer disc to 86 camaro
Not unless the 86 had discs. And then you may need a spacer.
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
True, unless you modify ( trim and redrill ) the end flanges. That's what I did.
1 Post
Engine: 305 tbi
the disc rearends have different flanges.as i understand the later disc brakes will bolt on with a spacer.just what i read in this forum.flynby sells a bracket to install lsi brakes without modification.
Car: 91 formula ws6
Transmission: 4l60E
He does sell a nice bracket. At the time I was too poor but had access to machine tools. Removed all the drum brake components ( worn to hell) made some measurements and center punch marks, then removed the top part of the flange and redrilled.
OP, if you are not comfortable with drills and cutoff wheels, do not modify the end flanges. You may screw yourself. Anything can be made to work with a lot of research and some experience.
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
