Upgrading a 91 W/Rear PBR Brakes to Front 1LE.
Old 09-11-2015, 10:32 AM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
My 91 Formula came with stock rear PBR brakes. Is the PROP valve any different between my car and a 1LE? I might be upgrading my front brakes to 1LE.
Did some searching couldn't exactly find it.
Old 09-11-2015, 11:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Upgrading a 91 W/Rear PBR Brakes to Front 1LE.
I just put the front 1LEs on a 89 car with a PBR disc rearend, didn't swap the prop valve and they work good.
Old 09-11-2015, 12:42 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
OK good, I was thinking the valve would be the same since the 1LE use the same rear brakes.
Old 09-12-2015, 08:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Shouldn't be an issue. There's a combination valve for each of the three braking applications: disc/drum, disc/standard disc, and disc/1LE.
JamesC
Old 09-14-2015, 12:45 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
or just take the spring out of the stock prop valve and put an adjustable valve in the rear line to really dial in your brakes..
Frozer!!!
01-19-2024 04:55 PM
ZMWojnar
Brakes
05-12-2019 10:43 PM
Eric-86sc
04-03-2016 03:52 PM
Reddeath210
10-06-2015 08:20 AM
Quick Reply: Upgrading a 91 W/Rear PBR Brakes to Front 1LE.
