Pad change problem.
Old 10-04-2015, 01:25 PM
1nastyRS's Avatar
Car: 1992 Camaro RS under construction
Engine: Building 500 rwhp ls1
Transmission: 4L85E
Axle/Gears: Moser Ford 9" 3.70
Pad change problem.
I got new brake pads for my car, and changed them, but the little spacer for where the caliper screws into the mount doesnt fit after the change. i put the old pads back on, and the spacer went in, but it was a tight fit. i dont understand whats wrong.
Old 10-04-2015, 02:06 PM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Pad change problem.
the small round 'spacers' that the caliper attachment bolts go through will slide on a rubber bushing within the caliper where they mount. just use some effort to slide in or out to where the caliper will fit back on the spindle.
Old 10-04-2015, 07:46 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
mount the caliper without any pads in it and slide the caliper over on the pins... it should slide back and forth easily. if not, spray some liquid wrench or similar on it and keep moving it back and forth until it moves easily without any binding. then when you put the new pads in, put a little high temp grease on those bushings to keep them free..
RS Reaper
10-17-2018 07:52 PM
Arctic White 91 RS
Convertibles
23
01-19-2016 01:19 AM
JHutch440
10-04-2015 07:41 AM
Linson
10-01-2015 09:50 PM
Jlanz55
09-29-2015 08:55 AM
Quick Reply: Pad change problem.
