Nitrous or complete LS1 brakes
1 Post
Car: 1992 Camaro z28
Transmission: Automatic
Axle/Gears: Stock
Torn between a complete ls1 brake conversion from and back. I have a 1992 camaro z28 350 with the j65 code. Single piston brakes all around. I have braided steel lines from earl drilled and slotted rotors and high performance ceramic pads with less than 1500miles on the setup. Or should I go with nitrous for my modified engine. Advice please
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Nitrous or complete LS1 brakes
nitrous, unless you road race which is 5% of this community.
stock brakes with high performance pads and rotors are adequate for street driven cars.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm going to disagree as many of the 3rd gens were 14 second and/or 150mph cars from the factory and could barely stop from 60mph in 140 feet. LS1 brakes would drop that by at least 30 feet, giving much more braking safety and even better performance when warmed up.
11.70s 10.50s with NOS.. stock brakes are fine always have been on my 92 z28 350 car.
.. I have added wildwood calipers with all the new upgrades..
even with 6"wide front tires.. I don't drive hard on the streets.. slower then most as I cruze it...
cowansauto
01-30-2022 05:06 PM
