Losing my mind - brakes barely working
Old 01-28-2017, 09:07 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Well, I parked my camaro for a few months to swap my 6 speed for an auto (long story) and ever since I did this, my brakes suck. I'm not sure how this happened since I didn't touch anything with the brake system. I figured maybe the master cylinder went bad from sitting so I went ahead and went through the whole system and rebuilt the rear calipers, replaced all the rubber hoses, and put a new master cylinder on the car. I have bled the system 5 times now, and even purchased a power bleeder and did that today but nothing has helped. There is no air and the pedal is really stiff while bleeding but as soon as I start the car, the pedal becomes really soft and pretty much goes to the floor when trying to stop.
The car is a factory 4 wheel disc (non 1LE) with a 4th gen rear and stock front brakes. The brakes worked great before I swapped the trans so I am at a loss. Is it possible the prop valve went bad? Or maybe the booster? I've always been told if the booster goes bad, then I would have no power assist so I doubt this is the problem. And if the prop valve went out wouldn't I still have good pedal?
Old 01-28-2017, 10:19 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Losing my mind - brakes barely working
have you tried bleeding it with the car running?
Old 01-28-2017, 10:25 PM
1981LT1's Avatar
Engine: LT1; LT1
I have not. I've thought about it but I've never had to do that on a car.
Old 01-28-2017, 10:51 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
IDK why, but i always bleed with the car running. i'm not sure if it's nessecary, but my thought is the power booster would have more pressure. cant hurt to try it.
Old 01-29-2017, 07:09 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Did you bench bleed the master cylinder before putting it on? If you did not take the short clear brake line kit that came with the master cylinder then disconnect the brake lines. Connect the clear hoses and put the open end of clear hoses into the reservoir of the master cylinder and pump the brakes until no more bubbles come out
Old 01-29-2017, 11:24 AM
1981LT1's Avatar
Engine: LT1; LT1
Yes I bench bled the master.
