87 Iroc "10 second car"
Merkel Racing N.Y. built the motor *Dynoed @ 550+ hp motor only*
383 cid, 4-bolt (orig zz-4 block) Eagle crank & rods, JE SRP pistons 10 to 1
Comp cams solid roller, Brodix Track 1s *flowed 315 cfm*, Brodix intake,
BG 750 Demon carb. Less than 10 miles since new !!!
Turbo 350 trans rev. pattern w-brake ( Built @ Rogers trans in Chantilly)
Coan 10 inch Conv w- reinf sprag. Less than 10 miles since new!!!
Aeromotive A-1000 fuel pump, filter reg, #10 line front to back, stock tank w- fitting at rear lower. N2O Cheater plate system.
Headman headers 1 3/4 long tubes, 3 inch y-pipe, 4inch mufflex system w- flowmaster.
Moser 9inch rear 4:10
S&W "Suspension Kit" incl frame connectors, trans crossmember, torgue arm, lca, panhard bar, Spohn Drag-Anti roll bar, Qa1 (not installed) rear shocks, Centerline Telstars front & rear w- 28x11.5x15 Mickey Ts ET Steets. ** comes w- but not installed** Art Morrison Chomemoly 12pt thru the dash cage w-swing out bars !!! Body is decent, so is the interior.
Price is $7k . 8am-8pm EST 703-577-6881 Todd. Thanks.
Last edited by TdyGTA; 07-04-2007 at 01:33 PM. Reason: omitted which rear was in car
Car: 1986 Iroc
Engine: 406
Transmission: Powerglide
Re: 87 Iroc "10 second car"
What rear does it have in it 12 bolt 9 inch? I would like to see some pictures of the interior if you have them. Could you please e mail them to njstangs@optonline.net
Car: 1986 Camaro-trashed/rust bucket
Bad idea for a street car? Almost but not fully a daily driver? If not then I'm interested.
What i ment to say was, if it can be used for a daily driver, I am interested.
Last edited by 86'Frankenstein; 06-13-2007 at 09:01 PM. Reason: Automerged Doublepost
mustangman65_79
08-11-2015 03:17 PM
