91 rs lo3 t-5 missouri
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
i have a 91 rs red with black strips, the car has had a lot of work done to it the reason alot of these parts where due to dianosing a problem witch ended up being a horribly bad clogged cat converter. some things include timing chain and gears, tps sensor, intake gaskets,clutch and pressure plate flywheel ground down,altenator, waterpump, knock sensor, and other varois sensors, the injecters where taken out and sent to have cleaned, the body is decent paint is ok some overspray from i guess someone had it painted, it drives like a charm theres more parts here and there sway bar busings tierods centerlink and idler arm fuel filter, and i had a leak in the raidiator so replaced with brand new aluminum and new hoses, thats all i can think of right now you can call me at
314-315-0919
the bad on the car, ok the two back rims where dented so I just have two 15s on the back. But i have a set of 95 camaro rimes that just need 3/8 spacers for a little extra money.
at idle the car sits there and the rpm will go up and down not huge but it does i havnt had time to find out what it is, the car runs fine just when at idle sometimes it does this.
upon start up there is some smoke so i guess that means valve guideseals other then this the car doesnt leak or burn oil has a nice healthy motor with around 80000 miles on it. thats about it
ive always changed the oil in it around 2000 miles since ive owned it which is like 6 times maybe. the transmission and diff have had fluids repaced as well the car shifts through every gear smoothly umm mif you possibly need more info email or call studebakerjones@msn.com
314-315-0919
Car: 1988 Camaro
Engine: 305 TBI
Axle/Gears: stock 2.73 open diff
Re: 91 rs lo3 t-5 missouri
could you post some pics. just wrecked my '88 and i need a new car to hybridize with built 383. if it is still available email me pics at Fratley_1@yahoo.com
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
pics sent but just got about 8 more today soo if you still want just message back
Please send pictures to stevemoree@***.net. Any rust in the body or under the car? Where is the car located? How many miles on the car?
Engine: Cammed 6.0L LSX
Pictures to studcamaro91@yahoo.com please. Also where in MO are you located?
sorry, that i never got back to anyone just some problems accured. the fuel pump died on me so during that process i put in a 9 bolt 345 disk posi.
and new interior. so im not sure unless someone qoutes me a nice price im probably just going to keep and the pump is an upgrade for a tpi setup witch i have planned
