84 berlinetta project car, free paint job + lots of extras, Need GONE!!!!!
ok well here we go, the I converted the body to the Iroc body stylings so louvered hood, bumpers and skirts from 86-90, I had the floor pan, windshield frame and driver side rocker panel replaced, it has brand new carpets which have been jute padded and sound and heat insulated, new door panels, new PPG windshield, chrystal headlight enclosures with halos, 2 sets of rims one with rubber, it comes with a set of tints for the car, a custome sub inclosure for the rear well area, Iroc tail lights, new front brakes premium rotors with ebc green stuff pads, calipers changed, just put in a posi rear end out of an 87 z28 with 3.08 gears and replaced the rear brakes, I put in an oem electric fan, the motor is currently a 305 H code (150hp 240torque) carb motor paired with a 4 speed 700r4 overdrive tranny( automatic) but the car also comes with a 305 tpi (tuned port injection) motor code lb9 (220-235hp 290-320 torque) with the wiring harness and computer A/C components emission components and accessories, a borg warner T5 5 speed manual tranny(might be a T5 world class not sure)with clutch master and slave, a full performance exhaust system, 2 front z28 springs, mac tools tack, the 2 front speakers come with the car they are infinity kappa, from the rear seats back i installed sound deadning sheats, entire floor pan in passenger area has been coated in rubberized rocker guard, the car has a digital dash with power mirrors, pwr locks, intermitant wipers, new p/s pump an wiper motor, now as for what the car needs, I changed the carpets to black but I didn't have time to do the rest so it has interior that got taken out and painted black but would look better with a real black interior, it needs a oem driver side front fender the one on it is brand new but aftermarket so the gaps don't match, it needs the passenger side rear wing piece ( like $35), it needs the front skirt for the bumper($180-$280), a pair of turn signals($65) one leaks water but still works fine, I changed the rear deck lid and and missed a gap where the sealant should contact the weather stripping but the body shop will fix it, it needs doors seals there like $65, if you put a stereo in I would suggest heavier springs in the rear, and the reason I have the z28 springs is because one of the front springs cracke near the end but I can't rent the tool to change them and the sit lower , with alot of the F-bodies ( camaro's and firebird's) they have a leak in the firewall and the passenger side I wanted to fix it but never had the time to pull the dash, It needs one turn signal bulb socket ($6) on the drivers side, fuel lines are in need of replacement in the near but not immediat future, the car runs good and strong, drives fine, needs an allignment but the than that no issues I drive it every day to work which is why i have to sell it, i do construction apprentice so i work mostly downtown toronto and gas kills me, and I try to keep the interior cleen but the dust goes all over the dash, I have put over $8000+++++ into this car so if you want my loss is your gain, oh yes and as for the paint job the is white so it will be painted white I did though inquire the other day aat my body shop to have the car go black and they told me about $1000 extra jams and all, so thats all i can think of right now, call me for more questions at 647-885-8603 i work 7 - 3 during the week
thanks jason coletta
toronto, ontario canada
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
Re: 84 berlinetta project car, free paint job + lots of extras, Need GONE!!!!!
location helps
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Pictures would be a good idea too...
colton_carlson
03-08-2019 12:21 PM
