[NC] 1992 1LE Z28
Want a title? Post!
1992 1LE Z28
1992 Camaro Z28 with RPO “1LE” performance equipment. This car has just 46,000 original miles and is in awesome condition.
There were 705 Camaros built in 1992 with the 1LE brakes. Of these, 589 were B4C (Special Service Package) cars built on the RS trim level and intended for law enforcement use. Of the 705 big-brake cars, only 116 were built as Z28s - they don't come up for sale every day - and this is one of the best ones remaining. Most Chevrolet dealers were unaware of the RPO 1LE package as it was not advertised.
The Z28 version of the 1LE performance package was intended to make the Camaro competitive in SCCA (Sports Car Club of America) road racing events. A combination of the top performance hardware available, combined with weight savings of a minimal option load, made this the lightest and best-handling of all third-generation Z28s.
The 1LE package on the Z28 came with the following equipment:
Choice of 5.7-liter TPI engine with automatic transmission (245 hp) or 5.0-liter TPI engine with manual transmission (230 hp). This particular car has the 5.7/automatic (350).
Dual-converter performance exhaust
4-wheel power disc brakes with special 12” front rotors and PBR dual-piston aluminum calipers adapted from the Corvette
Baffled fuel tank to prevent fuel starvation when cornering
245/50ZR16 Goodyear Eagle tires
145-mph speedometer
Polyurethane bushings
Special spring rates and shock/strut combination
Engine oil cooler
Aluminum driveshaft and spare wheel
Performance rear axle ratio
Fog lamps deleted for weight savings and better airflow through the radiator
Air conditioning deleted (only the Z28 1LE cars were A/C-delete) - improves weight distribution and radiator airflow.
This Camaro has a few extra-cost convenience options: a retractable rear cargo shade, power windows and door locks, tilt, cruise, and rear window defroster.
The car was professionally appraised by A.A.G. (Auto Appraisal Group) and given a stated value of $19,000. From there I started adding performance upgrades. I’m all for keeping to the true nature of a 1LE Camaro.
The upgrades performed are as follows:
Flowmaster cat-back exhaust
Koni shocks and struts (3 position adjustable)
Hotchkis:
Strut tower brace
Rear trailing arms
Panhard bar
Rear sway bar
1.5” lowered coil springs
ATI ProCharger P-1SC supercharger (12# of Boost) polished with a 3 core air-to-air intercooler and booster fuel pump
MSD 6BTM ignition with soft touch rev-limiter
Flex-a-lite Electric fan
Optima Yellow top battery
Alternator (polished)
B&M Mega Shifter
Auto Meter Boost and Fuel Pressure gauges
Accel Fuel injectors
Splitfire spark plugs
Mallory Distributor wires
Competition Engineering roller rocker arms
Billet Specialties polished aluminum valve covers and breather caps
Moser 12 bolt rear end with 30 spline axles, 3.42 gears, Detroit Tru-Trac Differential and rear stud girdle
Includes all After Market and Original Parts!!!
$15,500 Neg. please text or call me at 704-491-3702
goto following link at photobucket to see pictures!
http://s1207.photobucket.com/albums/bb479/cookiepolo/
145-mph speedometer
Engine oil cooler
Hotchkis:
Strut tower brace
Rear trailing arms
Panhard bar
Rear sway bar
B&M Mega Shifter
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
