[VA] 1991 camaro rs project/ daily driver t56 350
1 Post
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
i have a 91 camaro rs that has been my project as well as my daily driver. it has lots of aftermarket suspension and drivetrain parts:
-305 replaced with 350 tbi with 50xxx miles on it. ported throttle body and open air filter
-mufflers and cats removed and glasspack in place of them.
-all new kyb shocks and struts with tokico race springs.
-front controls are rebuilt with energy suspension poly rubber and new moog ball joints.
-steering is ok. gear box is loose but i have reconditioned one as well as steering linkage. just need to be installed.
-front sway bar and steering brace from iroc z. front sway bar bushing are energy suspesnion poly rubber
-founders performance front strut mounts. they are 2 inches higher than stock to compensate for the lowered ride height. they and caster and camber adjustable.
*i swapped in a t56 6 speed manual from a lt1 fourth gen with 100xxx miles on it. i used a aftermarket crossmember so it can now clear dual exhaust and long tubes.
-it has founders performance rear control arms and panhard bar with adjustable rod ends. it also has relocation brackets for the controls arms to correct the geometry but they havent been installed yet.
- it has a posi disc brake rear with 3.23 gears from a 92 z28. posi still hooks both tires. i have correct prop valve for brakes but hasent been installed yet.
- it has bmr sub frame connectors welded in since the car is a t top and has a very loose chassis without them.
-the wheels are cragar d window 17x8 and 17x9 but need new tires. powdercoated black with blue and red pinstripe.
-body isnt in great shape but i have new doors and fenders from another car that are straight and dent free. also a hood from a z28 with brand new hood louvers.
-interior is in ok shape. i replaced driver seat with tenzo r racing bucket and instrument cluster with white overlay gauges.also have dash that has fewer cracks and is not dryed out.a dakota digital speedo converter to correct the speedo reading becasue of the t56. and a black grant steering wheel.
- a sony head unit ad 1200 watt xplode amp with two mtx 10's.
this car would make a great race car or fun beater daily driver. it get decent mpg. around 16 in town and 25 on highway. price is obo and open to trades. text pete at 757 968 2961.
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Re: 1991 camaro rs project/ daily driver t56 350
Sounds like great potential, and am interested but need to know what price range you are looking @ to see if its within my budget to consider.
Car: 1982 Z28/1986 Iroc-Z28/2005 Sierra
Engine: 355/LG4/L33
Transmission: SuperT10/T-5/4L60E
Axle/Gears: 3.73:1/3.73:1/3.73:1
Any pics??
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
