92 Z28 Complete Rebuild Must See
1 Post
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I posted a feeler before but didnt get time to gather all the information because of my insane work hours. It took months of debate but am very sad to say she is officially up for sale due to a number of reasons...
The car works greats, starts up every time, even after months of hanging out in the garage. I am sure I forgot some things but I tried to gather as much information as I could and I do have 80-90% of the purchase receipts for all the parts for this car. I tried to keep everything possible and I also have photos (somewhere) from the tear down of the original black car to what she is now. It took about 6.5 years and I did everything except the engine build and body work myself in my garage without a lift. What an experience.
Anyways, here are the details:
ENGINE:
Golen Engine Service 383 LT1 Long Block (Currently 1600 mi.)
9.5:1 CR
Ultra Dyne Hyd Roller Cam
Duration: Intake - 230 degree @.050" Exhaust - 238 degree @.050"
Lift: Intake - .573" Exhaust - .573"
Lobe Separation - 114 degrees
LT1 Aluminum heads, ported, three angle valve job, 54cc combustion chamber, 185 cc intake runner
2.00" Manley Stainless Steel Intake Valves, 1.56" Manley Stainless Steel Exhaust Valves
Block: Billet Splayed 4-bolt main, ARP Main Studs, Thermally cleaned and stainless steel shot.
Bored .030", honed w/ torque plates and pressure washed. Clevite cam bearings and pioneer freeze plugs.
Crankshaft: Eagle 4340 Forged steel Crank, internal balance
Connecting Rods: Eagle 4340 Forged steel H-beam Rods 5.7" Full Floating
Pistons: SRP Forged Blower Pistons
Rings: Hastings Performance Plasma-Moly Rings
Rocker Arms: Comp Cams Pro Magnum roller rockers 1.5 ratio
Bearing: Clevite H-series
Core plugs: Brass pioneer core plugs
Lifter: Comp Cams Hydraulic
Pushrods: Comp Cams Magnum 7.2"
Valve springs: Comp Cams 26918 valve springs
Timing Set: GM LT4 Extreme Duty Roller
Oil Delivery: Melling HIgh Volume pump, pick up tube and HD Drive
Oil Pan: Canton 6 qt Road Race
Gaskets set: Fel Pro
Head Bolts: ARP
NEW Moroso valve covers with breathers
Oil Catch can
Headers (Flowrite): Custom made 1-7/8" stepped down to 1-3/4" headers, jet-hot coated, true long tubes.
true dual exhaust 3" all the way, no x-pipe or h-pipe (would hang too low). No cats, Magnaflow mufflers IIRC.
Custom Stainless Steel center mount oval exhaust tips ($$$)
Ignition: All MSD, MSD 6A, MSD Opti and plug wires
32 lb/hr Bosch III Injectors
Custom modified LT1 fuel rails to run in parallel (independent rails) with full Aeromotive A1000 fuel system.
-10 supply line to splitter, -8 to each fuel rail, -6 return line.
Custom Griffen 1.25" radiator for LT1 in 3rd gen with dual SPAL fans.
Complete FAST XFI 2.0 system.
ALL Autometer Phantom II guages, includes A/F ratio. All custom wiring with new fuses.
NO Accessories, only Powermasters alternator. No A/C. Electric Mezier water pump.
No power steering and no power brakes. Manual brakes with Wilwood master (stops great with no issues).
TRANSMISSION/REAREND/BRAKES:
6-speed conversion with 3rd gen pedals
1997 T56 (trans am) - Tick Performance Level 2 rebuild w/ options:
new bearings
cryogenic treatment (included as part of level 2 rebuild)
Spec Stage 2 clutch
see following link for more details:
http://www.tickperformance.com/tick-...maro-firebird/
12 bolt strange rear end, bolt in third gen from Spohn
Eaton Posi, no ABS
Aluminum girdle cover
3.73 gears (street gears)
standard 1350 Pinion Yoke
standard axle flanges
33 spline axles
Wilwood Dynalite Pro Series rear disc brakes (4 piston) 10.5" drilled rotters, wilwood pads
Custom 6-piston Wilwood brake setup for front with custom brackets, 13" drilled rotors, Wilwood spindles
Stainless steel hardlines throughout entire car except at moving areas where there are stainless braided lines.
SUSPENSION:
Spohn Manual Rack Conversion
Spohn tubular K-member (chromoly) with K-member braces
Spohn tubular A-arms (chromoly) with spherical rod ends
Spohn front coil over conversion with Koni Yellows
Spohn rear coil over conversion with QA1s 300# springs
UMI Double adjustable Panhard bar and relocation bar
Spohn front/rear sway bars
Spohn T-56 swap torque arm
Spohn T-56 conversion crossmember with driveshaft loop
UMI Lower control arms and relocation brackets
UMI Wonder/steering bar
BODY/WHEELS:
Custom "Roll bar" with side bars mandrel bent for easy access in and out of car.
NOT a complete cage so I am told its a "roll bar" setup. It has the rear hoop with two bars that
run down to the rear of the car and two that run along the doors the floor just before the firewall.
Cowl was cut, raised and smoothed out across, wipers removed and glass cut for clean finish.
Firewall completely blocked off (except for wire harness) and made flush.
Rear mounted battery (yellow top)
Hawks SS Style hood
Hawks 5" spoiler
Hawks new front chin/spoiler
clear front signal side marker lights
New factory style fog lights (new in box, not mounted)
Rear truck area cut and raised to fit 15 gal fuel cell.
Rear bumper cut for custom center mount exhaust
Paint is a Dodge Color (Inferno Red Crystal Pearl). I believe 5-6 coats with 3-4 clear.
I have touch up bottles with the paint code on it.
Custom Boze Alloys Wheels
INTERIOR/OTHERS:
Factory dash retained, with factory 25th Anniversary z28 badge, factory carpet.
New leather racing seats with red stitching.
Red z28 shift ****.
Flaming River flat bottom steering wheel
*New speakers and wiring installed (stereo not complete - plan for custom fiberglass stereo
mounted in rear passenger seat wells). Will include subs/amps/stereo and all other
components.
This build is setup to run 12 lbs of boost and that was my ultimate goal - D1SC Procharger. Whoever purchases this car should only purchase the car with the intent to add a supercharger to run 9-12 lbs. Otherwise you will really miss out on the true potential of the build. We are expecting about 650-700 hp range with the supercharger on 93 pump gas. Chad Golen can verify the engine build as we have been in constant communication during tuning and have developed a good relationship. I am sure he will extend the same courtesy and service to anyone who takes ownership of this vehicle.
I wasnt there for the original dyno tune but I was told the car made just under 500 hp at the crank NA. I had since fine tuned the fuel tables a bit more because I have not been able to find a local tuner who knows the FAST XFI system (that I also trust and will pay the ridiculous amounts that are charged here in NY). The XFI forums are incredible and several people helped tune my car for free and now its running amazing. I previously had the factory computer and that just wasnt going to do it.
I have never seen a nicer thirdgen in person and with the supercharger on here this car will truly be a rare car to have in the years to come. Lots of time and money has been put into this build and my loss will be someones gain.
I am asking $28,500 OBO. Much more was put into the car with all the parts, body work, paint, time, etc. To build another like this will easily cost 50k+ if you pay for someone to do including the cost of all the new parts. All the parts on this car were purchased NEW. I also have the title for the car. Location is Long Island, NY.
I'll provide any pictures, videos, information to any serious potential buyers. Please PM me or email me at axp2170@gmail.com (fastest way to reach me).
I am in no rush to sell and will continue to maintain and occasionally show the car and local shows when I have time. I also have tons of original parts, random parts, fluids, and all sorts of other stuff that I'd throw in with the car as it would be more useful with the car than without.
Now, for the pictures....
ENGINE:
9.5:1 CR
Head Bolts: ARP
Oil Catch can
new bearings
Spec Stage 2 clutch
Eaton Posi, no ABS
33 spline axles
SUSPENSION:
BODY/WHEELS:
Hawks SS Style hood
Hawks 5" spoiler
INTERIOR/OTHERS:
Red z28 shift ****.
components.
1 Post
Car: 1992 z28
Re: 92 Z28 Complete Rebuild Must See
thanks for the comments. Again, no rush in selling but feel free to ask questions and inquire. I still cannot find another thirdgen like this one.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Sad to see it go. Hopefully it goes to someone who will cherish and take care of it as you did. 1 of the nicest cars on the board !
1 Post
Car: 1992 z28
Thanks! I still cant believe I have it up for sale. I guess it hasnt really hit me yet.
1 Post
Car: 1992 z28
I dont have many photos of the interior but here are some. Not the cleanest. There are no rear seats as i planned to installed a custom stereo but never got around to it. speakers are wired in though. The floor was raised to hang the mufflers higher to increase ground clearance as well so the factory rear seats will no longer fit anyways, however i do still have them and they are in near perfect condition.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Almost the same build as mine. Chad built my motor also an i was there when they assembled it. Great guy. Good luck with the sale
1 Post
Car: 1992 z28
price drop. Just took her out from winter storage. 1771 miles on the current build.
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Love the car. I am not a potential buyer, but can you post up more pictures!
I have a maroon 91Z and have always liked the SS hood and 5" spoiler combo. Haven't came across too many dark red camaros with that combo!
Awesome job on the rear bumper!
1 Post
Car: 1992 z28
Thanks. every sunday there is big gathering at the beach early morning. I usually take the car out there so thats probably the next photo op. I'll try and get more photos then.
The color looks dark in the shade but in the sun it really just explodes and brightens up like crazy. its a must see in person to really get the full effect. The metallic flakes make a big difference as well.
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Car: 1988 IROC-Z
To the seller.. it was an honest question. I didn't know if that was the original asking.. or the updated price drop. To 90camaro355RS -- take a breath, Sparky. Find something else to riled up about. I asked the man a question.
Thx!
j
Thx!
j
1 Post
Car: 1992 z28
But I did reduce the price realizing I will certainly not get anything near what I put into the build and to also try and entertain reasonable offers.
I work way too much to be able to enjoy the car. I started the build when I was much younger and just started working and was very ambitious and wanted to carry out my dreams. Now that real life has hit, I just cant keep up with the car.
I take the car out on sunday mornings when I can to the local shows and thats it. Oil change every 6 months and check the plugs every 3 months or less.
Question, why you call me sparky, only my friends call me sparky, I have a friend that lives in Austin Texas that gave me that nickname when we was kids in school, what part of Texas do you live in?
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Out of all the incredible things on this car I like the way you exited the exhaust. It is like the newer cars but looks factory for a third gen. Hard to fault this car in any area.
Car: 1988 IROC-Z
The only thing to say to that is again if you would have read the thread from the beginning you would have seen the original price and then would have known it was a price drop.
one of those two reasons.
Car: 1988 IROC-Z
Yes, this is the dropped price. I originally posted the car up for sale as a feeler to see what kind of interest was out there. After seeing some other cars for sale and talking to some others I realized I was asking for a bit much but its a tough pill to swallow after the money, effort and time put into such a build, particularly when there is none like this out there. And when there are similar cars (older camaro's) going for double and triple the price on ebay. There is nothing in those that you dont have in here other than vintage and work done in a profressional shop. All the parts are the same (fuel system, motor parts, electrical, etc.) as well as quality. I realize the LT1 is outdated but its built just as reliable as any other motor with tons of capable power with the setup I have it built for.
It is a beautiful car and if I didn't have as many as I do and the price were significantly less, I'd take a run at it. Seriously nice ride.
j
I have 4 inch exhaust into dual 3 inch but I used the chrome chevy bowtie tips. I like the oval ones from the late 60s Chevelles but your exhaust tips is the best ive seen on a third gen. I should have thought of that. I know I spent enough on the exhaust.
1 Post
Car: 1992 z28
Yea, the exhaust I have was not cheap. Between the custom headers, custom mandrel 3" tubing, and the rear tips i am well over a couple thousand with the majority of the cost being the headers ofcourse.
Who made your headers
1 Post
Car: 1992 z28
Flowrite Headers/Exhaust Systems in Long Island, out east in Long Island.
1 Post
Car: 1992 z28
Last price drop. Spread the word people. Just turned 1887 miles and running strong. Will entertain reasonable offers so if anyone knows someone who may be seriously interested have them send an email.
I can certainly provide plenty more pictures and even videos for those really interested.
axp2170@gmail.com
axp2170@gmail.com
Terrell351
06-13-2021 01:13 PM
GVMV
08-16-2015 08:01 PM
