[FL] 89 RS 3.4V6 $3,000 obo
1989 Chevy Camaro RS
-3.4 V6 from a 95 Camaro has about 90k miles
-Paint color is Tomato Red, has some issues where people in the parking garages downtown have bumped into it
-Automatic
-Grey interior
-122k miles, will increase as I drive the car daily.
-Working A/C
-T-top
-No rust
In the past 4k miles, including the 3.4 swap I've put on:
New MAF sensor
New IAC
New plugs
New plug wires
New dizzy
New ignition coil
New power steering pump
New power steering high pressure line
New water pump
New radiator
All new gaskets on the motor
New injectors
Lakewood 90/10 struts
Founder's Performance strut mounts
New alternator
New battery
New belt tensioner
New accessory belt
New brake pads
As far as other things I've done to it:
Lowered it
1000 watt amp with 2 10in bazooka tubes
Sony head unit with aux port
New GM turn signals
T-Top over head console
IROC wheels
IROC steering box
IROC sway bars
IROC front steering brace
Rear seat delete
LED interior lights
I've had this car for 4 years, since I was 16-17. It has been my baby since but its just time to move on. I'm only selling because I could use a little extra for a down payment. I've cared for it, I've got a folder full of receipts of stuff I've done to it. As far as interior, I'd give it a 7/10. It shows its age, wear on the driver seat, carpet needs a good clean, and its missing the headliner, I have the piece to go there, just needs to be recovered. It runs fine, and I get about 20 MPG city from it, but it runs a tad rough at temp because of a vacuum leak I believe. Currently the gauge cluster lights do not work, but the cluster works, the circuits on the back failed but I am in process of getting a replacement.
I'll answer any questions you might have. Below is a link to my Flickr album of a majority of the pictures I have of the car. Looking for $3,000 OBO
http://www.flickr.com/photos/1013959...7635393144361/
-Automatic
-Grey interior
-Working A/C
-T-top
-No rust
New MAF sensor
New IAC
New plugs
New plug wires
New dizzy
New ignition coil
New water pump
New radiator
New injectors
New alternator
New battery
New belt tensioner
New accessory belt
New brake pads
Lowered it
New GM turn signals
IROC wheels
IROC steering box
IROC sway bars
Rear seat delete
LED interior lights
no green
01-09-2016 09:22 PM
skinny z
10-05-2015 06:23 PM
