[IN] Orange IrocZ Roller, Lots of New Parts!
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Thinking about selling My 1988 IRocZ project car.
Tons of new parts. Look at my Build thread for details, but here is a quick rundown.
https://www.thirdgen.org/forums/memb...-3rd-time.html
99% of parts are brand new never used
1988 IRocz non t top original L98 car
Front fenders are new, Jongbloed Hood
Metco weatherstripping
Custom Orange paint with HOK copper penny Ghost SS Stripes. Paint is 8 years old, has some chips and needs wetsanded and buffed.
Entire underside has been striped to bare metal, POR 15'd and painted Orange.
New Fuel and Brake hardlines need installed.
New Walbro Fuel pump installed.
Front suspension has Poly bushings
New Koni Sports
New Founders Strut Plates
36mm sway bar
WS6 Gear box
Jeep steering shaft
Edelbrock STB
Rebuilt stock brakes with Hawks HPS pads, earls SS brakelines
Rear suspension
Jegs Adjustable control arms
Founders adj Parnhard
Founders Panhard Relocator
Jegs Panhard bracket
Founders LACRB welded on
Jegster adj TA
Koni Sport shocks new
24mm swaybar
Spohn SFc's not installed
9 bolt rear 3.27 ratio, with TA performance Rear cover, TA cap studs, new brakelines, rebuilt brakes, new rotors, Hawk HPS padsnew parking brake cables, etc
Interior has new headliner, newer carpet, all black, black door panels.
nice dash, Have 4th gen seats, ok shape.
Have 5 speed pedals, New clutch hydrualics
New brake booster, new master cylinder, 1LE prop valve with new hd spring
AC delete box, new motor mounts,
Brand New Racestar 17x9.5" wheels, with BRAND NEW BFG Comp G Force SPort II tires.
yadda yadda yadda
T-5 wc trans, New Ram Clutch, Musclecar series, IIRC. Bellhousing, etc....
Selling it less engine
This is a Roller project, with many many new parts. I am not really sure I want to sell it, but have too many projects.
Lots more included, will put together list for interested parties.
Asking Price is $4000 rolling. Add it up, a ton more invested!
Will consider in
Not looking to part out at the moment so don't ask. I will post parts if I decide too.
New Koni Sports
36mm sway bar
WS6 Gear box
Jeep steering shaft
Edelbrock STB
Rear suspension
Jegster adj TA
24mm swaybar
yadda yadda yadda
Will consider in
Car: 1992 Z28 Convertible
Engine: 5.0
Re: Orange IrocZ Roller, Lots of New Parts!
Sent you an email and pm with a couple questions
Car: 1971 Camaro
Engine: 427
Email replied,
sent you my phone number if you want to talk.
Car: 1971 Camaro
Engine: 427
Some other new parts include, heater core and radiator.
Idler arm, inner and outer tie rods, Edelbrock tie rod sleeves.
Balljoints were replaced awhile back as well.
4th gen aluminum driveshaft, new prothane tranny mount
Good black arm rests,
TPI filter box and K&N filters
New poly urathane rear bumpstops
Engine: 5.0
Per our conversation, we have a deal, thanks!
Car: 1971 Camaro
Engine: 427
Complete Engine harness from a TPI 5 speed AC delete car
Newer air dam
power mirror set
manual mirrir set
wiper motor
used hedman shorty headers
Gray Seat belts, I thought I did not have any, but I do have a complete set of gray belts included
lots of extra interior trim parts, several door panel switch plates
New heater core
New rear parking brake cables
Edelebrock strut tower brace
speedo cable
black sail panels
gray sail panels
gray sun visors
new power steering hose
new idler arm
new motor mounts
new power brake booster
Aluminum 4th gen driveshaft
2 sets of rear spring isolators
new lower radiator hose
new radiator
new extra long front wheel studs not yet installed
2 set of dual radiator fans
lower shift boot
clutch fork
T-5 trans
New in box Ram clutch set 92730
New Prothane trans mount
new speedo drive to match rear gear set so speedo reads right
bellhousing
2 transmission crossmembers
extra relay panel with relays
extra rear hatch motor
NEw Ac Delco Clutch hydrualic set pre bled in box
24 mm rear sway bar with new greasable mounts
TPI intake box with K$N filters
The car is dusty and dirty, looks like a barn find!
The interior, heater system dash need reinstalled
The drivers window track needs to be remounted, took it apart top replace the power motor, but did not. Both windo motors worked but are slow
Ther are new window felts, weahtherstripping and hood bumpers, new when car was repainted.
Has GM lower pressure hood struts to match the fiberglass hood.
New lower door seals not yet installed.
Several boxes of hardware and random parts, extras ,all bagged and labeled as well.
Newer air dam
power mirror set
manual mirrir set
wiper motor
New heater core
speedo cable
black sail panels
gray sail panels
gray sun visors
new idler arm
new motor mounts
new radiator
lower shift boot
clutch fork
T-5 trans
bellhousing
Car: 1971 Camaro
Engine: 427
Black carpet front and rear, new a few years ago as well.
Over $1200 invested in brand new wheels and tires,
Moog front springs, half coil cut off.
4th gen z28 rear springs, cut,
pics,
http://s23.photobucket.com/user/clownj1988/library/
pics,
Car: 1971 Camaro
Engine: 427
Just noticed, it seems all the nice 3rd gens in my area are on the board here for sale!
Looks like I'll probably be finishing up mine, as no one is interested, after getting several people telling me "consider it sold" only to never hear from them again.
I was really wanting to get another truck, but as long as this one is in my garage, I can't.
I may put it on CL looking to trade, otherwise, I guess it will stay with me.
I'd hate to part it out, and end up with a shell I can't get rid of, but with the parts list of new parts, I could easily get my asking price in parts.
Oh well, maybe someone will get a big Tax check and come pick up the easyist project car around!
Car: 1984 Camaro Z28
If you still wanna sell it I might be interested. Are there any current pictures of it?
Car: 1971 Camaro
Engine: 427
Most current pics are in build thread.
It's on jackstands in the shop right now, I could text some pics in the evening
Car: 1971 Camaro
Engine: 427
I'm not too far if you want to check it out in person.
Yeah I may be down that way this weekend! Definitely be interested.
Car: 1971 Camaro
Engine: 427
$3000 without the racestar wheels.
I got another vehicle, this car needs to go.
I hate the idea of parting it, but that's next if someone doesn't want it.
Car: 2010 Camaro
Engine: 416 ls3 Mike Norris tuned
Transmission: rpm stage 5 tr6060
Axle/Gears: stock
on your photobucket which iroc is it that is for sale?
Car: 1971 Camaro
Engine: 427
The orange one is the only Iroc I have. It is the one for sale. It has now been stripped of all suspension.
Most suspension parts have already sold.
junkcltr
08-02-2019 11:12 PM
IrocZ'85
08-17-2015 06:24 PM
