Camaros for Sale Post your Camaro for Sale.
[GA] '91 Camaro Z28 drag/street
Old 05-26-2015, 10:24 PM
1991project's Avatar
Car: 1991 Z28
Engine: 408 LSX
Transmission: Pro-shifted T-56
Axle/Gears: 9"
1991 Camaro Z28
Odometer shows 140,000 miles, artic white, t-top (glass), 4" harwood lift off cowl hood, currently set up for manual transmission including clutch pedal and hydraulics. I've owned this car since 2002 with a clean title. It is a drag/street project featuring mini-tubs fabbed from .040 black aluminum, 1 5/8 diameter chrome moly 6 point cage/roll bar, chrome moly k - member and a arms with pinto rack and no motor mounts or spring perches, strange manual brake master cylinder, Hurst roll control line lock, ls f-body front brakes, strange mustang single adjustable front struts with coil over spring, chrome moly double adjustable rear lower control arms and Panhard rod, 9" rear (factory style with backbrace) set up for coil over shocks with thru-bolted aluminum center section (3.250 bearing, steel 35 spline spool, 3.90 gear) Moser axles (5 on 4.5" and 5 on 4.75" patterns), strange double adjustable coil over shocks, two factory black seats, new black carpet, and grant steering wheel. Over $6500 invested Asking $5000 near chattanooga tn.
Frozer!!!
01-19-2024 04:55 PM
CarGuyDennis
137
12-06-2016 11:02 PM
GVMV
08-16-2015 08:01 PM
GVMV
Exterior Parts for Sale
08-16-2015 07:08 PM
greeny
Wheels and Tires
08-12-2015 03:55 PM
Quick Reply: [GA] '91 Camaro Z28 drag/street
