Camaros for Sale Post your Camaro for Sale.
[NC] 1992 RS BUILT 350 5-SPEED
Old 03-20-2016, 11:03 AM
Want a title? Post!
I_R_GRUNT's Avatar
1992 25th Anniversary RS painted in 2004
350 bored .060 over
Aluminum fast burn heads with Cometic head gaskets
Speedo pro Forged FT4v pistons
LT1 rods
Stock crank
ARP head bolts
ARP main bolts
Most bolts are ARP on the motor
1.6 GM roller rockers
RPM air gap intake
750 DB Demon carb
Lunati bracket master .480 cam
Hooker super comp longtube headers ($1200 headers)
Borla Catback
Electrically Controlled Exhaust Bypass Valve, 3.0"
Brand new custom interior two tone ebony ultra leather with perforated black micro suede inserts and red double loop stitching by Lethal Interiors ($1,500)
New Functional DuraFlex fiberglass WS-6 hood ($600)
New Mickey Thompson ET Street Radials in the rear, R2 Compound is soft. ($250 per)
New high temp Thermostat
Fresh oil change with mobile 1 synthetic
Entire car is structurally sound and has many added braces to keep it straight.
MSD distributor, coil ,and 6al box
4.10 gears with eaton posi , 28 spline GM axles in a 10 bolt
Ultimate rear end brace and aluminum cover
Tubular front crossmember and control arms
Spohn rear LCA and panhard bar
Weld in sunframce connectors
Borg Warner World Class 5 speed with a Zoom dual friction clutch
Moroso 7 quart oil pan
New alternator
High torque 3hp Speedmaster starter
Braided steel brake lines
Drilled front rotors
KYB struts and shocks
Sun pro tach and a CSI temp/electric fan controler.
Glass T Tops
All the factory wiring was removed and the car was put on a switch box.
All lights work outside aside from blinkers, wipers work, horn is on a switch
Power windows
Grant steering wheel
💥💥💥Looking to sell or trade, make me an offer!! Please text me 8104172180💥💥💥
Fireball
04-29-2016 12:15 PM
'91CamaroRS
03-12-2016 09:44 AM
blascwil
03-07-2016 12:21 PM
edpontiac91
03-03-2016 08:18 AM
Abubaca
02-23-2016 09:23 AM
Quick Reply: [NC] 1992 RS BUILT 350 5-SPEED
