Canadian Region Take off to the Great White North.
Roll Call: Manitoba Members Step Inside!
Old 05-31-2014, 11:13 PM
  #251
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Roll Call: Manitoba Members Step Inside!
This guy has parts.
http://www.kijiji.ca/v-auto-body-par...ationFlag=true
Old 06-24-2014, 10:02 PM
  #252
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Hey boys! Does anyone know where I can find a IAC valve? Piston ring wants a fortune for it?
Old 06-24-2014, 11:24 PM
  #253
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
www.rockauto.com
Old 07-09-2014, 01:44 AM
  #254
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Who's relatively sound when it comes to Tuner Pro RT?
I've read threads for the last 5 years on prom tuning but I'm missing something I guess.
I'm trying to tune the 11:1 forged 383 that I built, with a HSR/AFR 180 combo and XFI 268 cam.
Shouldn't be too hard but I'm either too rich or too lean (have wideband) and nothing I do seems to really make a difference.
I've played with scalars and MAF tables, dabbled with PE/AE and timing.
I've used my original APYU Bin,an ARAP Bin and even uploaded my old ADS Superchip Bin as starting points...
I can get the car to idle well in park 13.5-14.5 AF Ratio @ 700 RPM but light throttle goes lean 17-20 and sitting at a stoplight I run 10:1 rich WTF!!!!
WHO ELSE IS TUNING 165 6e IN WPG.!!!
Old 07-10-2014, 09:52 PM
  #255
572_Rat's Avatar
I am not sure, but give Mike a call at Sandale, he will probably know someone
Old 07-17-2014, 11:09 PM
  #256
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Wolf performance used to do it. Ed might be able to refer you to someone.
Old 07-17-2014, 11:27 PM
  #257
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks, I've been dabbling...
I'll look into both suggestions if I wave the white flag.
Honestly I was hoping someone would say,
"I just finished tuning a HSR, I'd love to come for a ride and tap some keys..."
Old 10-12-2014, 07:55 PM
  #258
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Who's wrecking a firebird? Looking for a headlight module 91-02 should work
Old 11-26-2015, 11:01 AM
  #259
572_Rat's Avatar
I have some Aerospace pro street front brake kit for sale, they have about 2100 miles on them, they work perfect, just bought some Wilwood to replace them. When they did the back half they put Wilwood on the back, and I just change the master cylinder to Wilwood to clear valve covers. So I decided to change front to match the rest of the system
Old 03-10-2016, 05:58 PM
  #260
Project82's Avatar
Hi Guys, just thought I'd say Hi, I've been following this site for a while now pondering the idea of bringing my 82 Z28 back to life. Long story short...I am picking it up from the farm at Easter and then the fun begins. The car has been sitting for 15 or so years (but started regularly). Also if anyone has any spare kicking around let me know, I am at square one and looking to upgrade almost everything.
Jordan
Old 03-11-2016, 11:07 AM
  #261
572_Rat's Avatar
Welcome Jordan, to bad were did not post before, I finally threw all my spare parts out, tried to give them away for years
Old 03-12-2016, 08:21 PM
  #262
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
What parts are you looking for?
Old 03-13-2016, 09:26 AM
  #263
Project82's Avatar
Well managed to track down most of the pieces for an iroc style body kit. I still need the lower passenger side ground effect. I was also looking for a hood....mine is fiberglass original but pretty beat up, I may try to fix it but if I can find an aftermarket one I may be interested. Any suspension/brake upgrades. It currently has a tired 350 w/a 350 turbo behind it.
Old 04-09-2018, 04:27 PM
  #264
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Hey Gents,
I'm looking for a differential shop that knows what they're doing and won't take me to the cleaners...
My 9 bolt rear end is tired and the posi is gone.
Id rather not do it myself if I could avoid it
Old 08-24-2018, 12:53 PM
  #265
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Anybody here interested in a set of ceramic coated long tube Hedders for SBC?
Hedman Elite part #68468
check Summit for all the details
1 5/8” primaries 14 gauge
3/8” thick flanges
3” ball flange collector with O2 bung
Couple dings by a local shop to get them in but otherwise they’re in great condition.
Went turbo.... so I don’t need these anymore
$250
SOLD
gta892000
08-11-2019 11:16 AM
RyanJB
Members Firebirds
39
11-20-2018 03:30 PM
Twin_Turbo
03-14-2016 10:10 PM
Linson
09-21-2015 01:08 PM
Fronzizzle
09-08-2015 12:10 PM
Quick Reply: Roll Call: Manitoba Members Step Inside!
