Crunch Amps any good???
Car: 1992 Camaro RS Convertible
Engine: 3.1
I'm looking to get an amp to power an Infinity Kappa Perfect DVC 10. So far the only amp that i have found that puts out the rated 350W RMS at 2 ohm is the crunch V-1200. Anyone ever run one of these or know if it's a decent quality amp.
What other amps would you use to push power to this Sub??
Also has anyone had any success mounting the Infinity Kappa Series 4x6's and 6x9's in their cars. If so how much modifying had to be done. I've heard they don't fit to well, but I've heard them in a friends car (not a thirdgen) and love the way they sound
Hey got to www.chrutchfield.com check out their amps. They should have all the info you need on the amps. As for a Crunch amp, I've never heard of them.
Tim:rockon:
Tim:rockon:
in a word, no. hehe
They are just like Pyramid, just a different brand name. As a matter of fact I think they are owned by Pyramid....
I would say just search www.thezeb.com www.mmxpress.com and ebay and find a name brand amp (new) that you like. You can get it MUCH cheaper than buying it at a store or through crutchfield. Just beware, some company's don't honor internet sells and won't have a warrenty, JL Audio is one of these. Read the fine print before you buy.
Location: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Never heard of them, but it sounds like it's probably crappy/
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
ya, you dont want to power such a nice sub with a crap amp. JBL 600.1 will run you about $195 with shipping. There is some room to grow with that amp as well. Kappa Perfects are sweet subs and if you power it with a nasty a$$ amp you wont enjoy all that it is worth.
Brian
Brian
Car: 88 GTA, 94 BMW 840, SVX, Prelude
Engine: 383 w/ Super Ram
Transmission: built 700R4 auto
Engine: 3.1
Thanks for all the feedback so far. How much power do you think that i can run to the sub safely if its rated at 350 Watts at 2 ohms with a peak power handling of 1400 W?
Actually, you want to run as close to the RMS rating of the sub as you can. The peak power rating of a sub (or amp) is not very meaningful. So, if you have a sub rated at 350w RMS @4 ohms, then you want an amp that delivers 350wRMS @4 ohms. Its not good for subs to run too little or too much power to them - most people don' t realize this, but more subs blow out from not having enough RMS power than from having too much. If you try running a sub with an amp that delivers 20w RMS, it'll sound horrible and blow the sub, due to the fact that when you crank the volume up on this setup, the head unit is asking the sub to do something that it's not being given the power to do. So in your case, I would get a good quality, name brand amp that's rated at 325 - 350w RMS@2 ohms.
the jbl bp300.1 puts out a rated 300 rms into 2 ohms, the bp series amps are underrated tho so its probably closer to 350.. it's a great amp, its clean power and it can be had for about $150.. but like was said before, you might want to put down an extra 50 bucks and just double your power with the 600.1.. keep your gain settings modest and you should be fine, perfects should be able to handle it no problem
Underpowering subs does not hurt them at all. If a sub is rated at 300 watts RMS and 600 peak, peak is just the max power rated for safe mechanical limits.
Underpowering subs is just that, underpowering them. What does hurt them, is when you have a 10" sub, and a cheap 50 watt amp, you crank it up, and the gain, pushing distortion into the sub. That is the bigger killer.
Hope this helps.
Originally posted by fly351
push them at peak.
i heard its actually not good for a sub not to be backed by its full capibilities.
-fly
push them at peak.
-fly
Car: 98 Trans Am 85 Trans Am
Engine: LS1 Lg4
Transmission: 4L60E 700r4
Axle/Gears: 3.23 2.73
I have a crunch amp and it seems to be a very good amp but I think mine is an exception to the rule as others that I hae seen and dealt with from crunch have not been half the amp mine is and the have all been about the same power rating of 200 watts RMS so I guess I got lucky.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hope this helps.
Hope this helps.
If someone has ANY sub that has an RMS of 350 watts, and they push it with a 50 watt amp, then the normal reaction is to turn up the amp, bass, volume, loudness button, or EQ to get the "DESIRED" sound. By doing so, they're causing the amp to clip. When the amp clips, it flattens the variation of current that goes to the sub. It's the same as hooking it straight up to a DC battery and leaving it there. That's how the voicecoil heats up, then seizes.
If you push the speaker beyond it's mechanical limits from too much power, you will more than likely cause the same thing, but not the same way. You will hear the speaker making funny noises and that SHOULD give you a clue to turn it down. When an amp clips, it's much harder for the common guy to hear it (taking into account the true audiophile is more likely to hear it.)
From my personal experience, I'd rather have a 500 RMS amp pushing my 350 RMS sub. For one..... subs are cheaper to replace than amps. For two...... any speaker I've blown was because I was under powering it. Once I was preparing for an SPL comp... and the night before I was "tweeking" it and *POW*!!!!! Smoke.
The other time I think it may have been more from the heated voice coil. My car was sitting in the sun for 8 hrs on a 100* day, and I got in, dropped the glass, and cranked the tunes. The voice coil didn't like that.
AJ
True, my post was for clarification...it is not from due to lack or power, just the pushing of distortion from the lack of power. that is user error..not the amps.
My system is stable
I have two crunch 4800TMC amps and they hit real hard.... weell mainly b/c of the two 12w3 Subs i have... i hit around 130 SPL.... but that was before the JL subs.... with my crappy Cerwin vegas.... but heres a pic of my setup....
This is the system a year ago
These are the current subs in the car...
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Decent amps...
Crunch is not crap. They have been around for at least 10 years. Check out their Fat Boy subs!!! Not everything that is not brand name and is fairly priced is crap, remember that. Sony = good, or at least many think so. Crunch = much better than sony. Sony = Hitachi parts ( remember Hitachi )
They are decent amps for the price but considering that the one for like 160 bucks is 300 watt and the 500 watt is 180, get the biggest one, you can always turn the gain down.
Oh yeah, when I was an installer and CROSSFIRE came out, we though it was pretty crappy stuff. ( campared to Rockford and PPI ) Now everyone rants and raves over it.
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Decent amps...
Originally posted by 330hp_91RS
Crunch is not crap. They have been around for at least 10 years......
Brian
Car: 91' RS
Engine: Built 355
Re: Re: Decent amps...
Originally posted by 89blackGTA
Rockwood and Kenford have also been around for that long, are they good in your opinion?
Brian
Brian
No they are not good. They cost about half of what crunch sells for.
All I am saying is that these amps are decent. They are not as cheap as they could be and because they are nor dirt cheap and have been around for quite some time, they have innovated and are continously making better products.
Anyone ever heard of Sherwood??? Most of you probably think it's crappy. WRONG. Fantastic sound quality and power. I have a 75x4 and it rocks. Dual power supply and dual cooling fans. Don't judge the book by the price or the cover. Ask for honest, experienced opinions. the rest of my amps are Alpine and Rockford, I have a quality system. Including the Sherwood.
CreatiVe2 has a nice system with these amps. 130 DB out of those weenie Cerwin Vegas is good, 130db period is loud. He says they are decent and have given him no problems, thet should tell you something.
By the way:
I found a place that has these amps really cheap. Go to
http://www.justamps.com/Amp_Pages/Cr...-Drive_new.htm
I did not see the V1200 but you should just spend the extra cash and get a big one, that way there is always room to improve the system.
Re: Re: Re: Decent amps...
My first system in my first car was a Sherwood cassette deck with a Sherwood amp. That was in 1987!!! It was a '65 Mercury Comet.
IIRC, Sherwood was THE first company to offer bridgable amps. Or at least that's what the shop where I bought mine said, and they were a Alpine, Rockford Fosgate, and Coustic dealer (if anyone remembers that brand). Although they also carried Craig amplifiers. Those were about as cheap as Rockwood and Kenford.
That Sherwood amp was the ****!!! I had the 4 channel with 2 channels running some Jensen 6x9's and the other 2 bridged into one 8" Ultimate sub ALL MOUNTED IN THE BACK DASH!!!!!!! :sillylol:
Man... those were the days. Me and my boys would ride around jamming out to Too Short, Digital Underground, and Eazy E!!!!! LOL OH YEA!!!!! And can't forget SuperSonic by J.J.Fad!!!!! We had chics all OVER that ugly *** car!!!
I gotta stop now..... or I won't stop reminiscing.
AJ
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Re: Re: Re: Decent amps...
Originally posted by AJ_92RS
Holy Crap!!!!! Are they still in business????
... and Coustic dealer (if anyone remembers that brand)... AJ
Brian
330hp_91RS
yo 330hp_91RS.. .thansk a bunch for the support.... the vegas did get that over a bridged 400 X2 @ 2 ohms and withthe same power the JLs hit much harder.... its not only the power going to the speaker that matters... its the actual quality and build of the speaker that makes the sound what it is..... rockford amps are famout for their whine... and i think thats the only thig that differs from my amps than rockfords at this level.....
Also power needed for a speaker is also very dependant of the application. The amount of wattage a speaker can hold is a thermal rating. In some application (such as porting a speaker) you may not need the total RMS power rating to achieve full xmax or sound good.
thats true..... i mean its also a given... if you are going to install a higher quality speakers you better pay attention what to do to make them work to their full potential....
Car: 91' RS
Engine: Built 355
Ok..
I want to clear something up really quick.
Earlier someone said to push subs at peak. I agree, but not at full peak. You should try to get an amp that will push more than a sub's RMS capability. Remember, those ratings are nominal and are for warranty purposes most of the time. A speaker with 125 watts RMS specs being pushed by a 200 watt RMS sounds awesome. Know why, cause the amp has no prob pushing the speaker to it's limits, it has power to spare. This is really good. You will have absolutely no distortion, most speaker " Bogging" comes from amplifier clipping and such, not cause the speaker can't take anymore. If you have 350 watts going to that same 125 watt sub, expect it to bog. That's just too much power.
Make sense??? Remember this guys. Spend the extra cash in the beginning if possible, and just turn the gain down, you'll thank yourself for it later!
thats what i did to my JLs.... and got rid of Vegas... my vegas were MAX power rating at 400 watts.. i was pushing 400 watts to each.... didntn sound THAT good... now My JLs.... are rated at 300 watts RMS... same 400 watts goign to it and they sound beautiful let alone they are JLs but they still improved much on the distortion level..
db057
08-11-2015 10:11 PM
