Let's see your custom speaker boxes!
Old 10-17-2012, 05:56 AM
  #401
ChevyFricknRuls's Avatar
Car: 1990 Chevy Camaro RS
Transmission: Automatic
Re: Let's see your custom speaker boxes!
Originally Posted by ScrapMaker
here are some speaker locations... in order from STRONGEST to WEAKEST bass... (using same speaker/amp/box volume)
1. Rear-Firing Well Box
2. Down-Firing Well Box
3. Glass-Reflecting Well Box
4. Rear-Firing Hatch Box
5. Down-Firing Hatch Box
6. Glass-Reflecting Hatch Box
7. Forward-Facing Hatch Box
8. Back-Seat Box of any kind...
you can easily test this with a small truck box that fits in the well... I moved it all around and tested the sound...
cleanest and deepest bass was rear-firing well
When you say rear- firing well box how do you mean? Sub is shooting towards rear of the car in the well?
Old 10-24-2012, 01:46 PM
  #402
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Old 10-24-2012, 01:47 PM
  #403
Jk_Under's Avatar
Engine: 305 5.0L
Pic should have been bigger, it messed up but oh well, i have mine set up as clean as i can, 2 10'' comps. 840 watt amp, it bangs.
Old 11-12-2012, 09:57 PM
  #404
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
i want to see some custom subs in convertibles
Old 11-20-2012, 01:26 AM
  #405
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
anybody with nice custom box in a convertible?
Old 11-20-2012, 06:11 AM
  #406
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
here is my convertible , also check out a previous post by me post #380
Attached Thumbnails Let's see your custom speaker boxes!-321505_270551332985117_1323415354_n.jpg   Let's see your custom speaker boxes!-272261_223693201004264_8201759_o.jpg
Old 12-07-2012, 09:46 PM
  #407
kyrenegade's Avatar
Car: 91 Camaro Z28
Axle/Gears: 3.42 Posi Disc
Here is mine. Took about a month from start to finish.
Pioneer double din DVR touchsreen head unit.
6x9 Rockford Fosgate Rear
4x6 Rockford Fosgate Dash
Audiobahn 12" Subs
2 micro ferad cap Audiobahn
2 Audiobahn Amps
Old 12-11-2012, 03:43 AM
  #408
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
Here its mine nothing special 2 Kickers 12" cvx's
Here is the latest
Old 12-11-2012, 09:08 AM
  #409
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Nice setup. But that Soundstream Bass Machine is trash. It makes songs that have bass sound like mud. But it's a good upgrade for heavy metal bass drums. Anything else that has true 50-150 Hz sound freq sounds terrible.
Old 12-11-2012, 03:46 PM
  #410
Engine: 5.0 V8
I actually like the sound with the sound stream is the old one before it was started being manufactured in japan or china. Thanks!
Old 12-11-2012, 03:49 PM
  #411
Aaahhh. I see. I've never seen an old one before. What I would like to have is one of the old school Rockford Fosgate amps. Those are true monsters.
Old 12-11-2012, 11:14 PM
  #412
Engine: 5.0 V8
I actually have 3 of them they look like thse one 2 for bass and one for voice http://sacramento.olx.com/rockford-f...n-iid-23309395 I just have them in my garage
Old 12-11-2012, 11:18 PM
  #413
I have the 600a4. But it's got a few burnt MOSFETS. I'm talking about the oooolllddd ones like this one.....
http://www.carstereo.com/images/clas...50.1%20011.jpg
Old 12-11-2012, 11:47 PM
  #414
Engine: 5.0 V8
Those are great amps They don't build them like that anymore
Old 12-11-2012, 11:50 PM
  #415
Nope. Those Rockford Amps are in the history books.
Old 12-30-2012, 09:49 PM
  #416
jims86's Avatar
Car: 86 Trans Am
Engine: Rebuilt 350 4BBL
Axle/Gears: 10 bolt rear 3.42 gears
I got a pioneer shallow mount box and cut back out to fit a regular 12in sub and boxed the back in.Its big enough to hold my amp and Cd changer.Will be getting a better sub(Dual for mock up and getting system working)and adding a small amp to run 6x9s in hatch area
Old 01-03-2013, 12:42 PM
  #417
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
This is my setup. Two MTX 12" subs were given to me; I found out one was blown. I remembered when I was younger, I had some Pioneer box speakers in my S-10 that had a 6" woofer and a slave 6". So, I went ahead and removed the magnet structure from the blown one, and made it a slave! The box is rather small (around .75) and fiberglass insulated for volume, but the slave moves opposite the powered speaker and makes it hit pretty good. I listen to rock and hard rock and you can feel the bass in your stomach, but most of it stays in the car.
I have a 400w Pioneer amp in mono powering this monstrosity!
Old 01-18-2013, 12:20 AM
  #418
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Originally Posted by OutLaw305
what do yall think about this ider in the works? Fabing it up with cardboard to see if i wanna do it.
Old 01-18-2013, 05:28 AM
  #419
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Originally Posted by basshead208
How do you change lanes?
Old 01-18-2013, 08:48 AM
  #420
Flip the blinker and turn the steering wheel. Nuff said.
Old 01-18-2013, 10:22 AM
  #421
Car: 86 IROC Z28
In my third brake light up on the back glass I put a back up cam and a 7" screen under the center vents on the dash. Both are on whenever the car is so I have quite the view.Let's see your custom speaker boxes!-back-up-cam.jpg
Old 01-18-2013, 12:16 PM
  #422
Jk_Under's Avatar
Engine: 305 5.0L
Awesome idea.
Old 01-19-2013, 05:23 PM
  #423
Car: 86 IROC Z28
hopefully this year im putting 4 DC lvl 3 15s on the DC3.5k amp and a 300a alt turned up to 18.5v charge and 16.2 float with Kinetik 16v batts. Im running a 200a alt on the sub amp and Stinger batt for the wall and a 140a on the car right now.
Old 01-19-2013, 05:32 PM
  #424
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Bass head I can't hear you coming down the street. Put some subs in your car why don't ya?? LoL.
That setup is insane.
Old 01-19-2013, 05:39 PM
  #425
Car: 86 IROC Z28
thanks, sometimes I cant even hear myself coming... down... oh, wait, lol
Old 01-19-2013, 11:55 PM
  #426
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
Where did you get the back up camera ?? I have seen a few but not like yours with the lines on the screen...
Old 01-20-2013, 12:23 AM
  #427
Car: 86 IROC Z28
go to ebay, type in 'TaoTronics LED Car Rear View' 18.00 free shipping. it has the video rca. there is also the same cam but wire less for like 25
i cut the ends off the cam and epoxied it ino the light
Old 01-20-2013, 12:45 AM
  #428
BigKeg's Avatar
Thanks.....
Old 01-20-2013, 06:40 PM
  #429
Car: 86 IROC Z28
Here's a new shot of the wall with a better view. Got the amp skins and you can see the Stinger batt int the 3f cap and 300a anl fuse. Dropped the ZX350.4 in the old pic as well as upgraded to 400w Pioneer 6x9s and new ZX650.4 with the ZX2500.1.
Old 01-25-2013, 09:51 AM
  #430
Red-Alert86's Avatar
Car: Red 1986 Iroc Z28
Engine: 350 Bored .40
Clean, Simple, and Loud! Built it around 7 years ago and recently re-installed it when I bought the car back after 5 years of missing it.
Old 02-06-2013, 08:27 PM
  #431
Car: 86 IROC Z28
Today I put a short vid on youtube that shows excursion ( kicker camaro wall) if you wanted to see em flex
Old 04-10-2014, 06:44 PM
  #432
Tdoggy7's Avatar
Thats awesome dude, could i get the dimensoins for that?
Old 09-25-2016, 12:50 PM
  #433
bk2life's Avatar
Car: 91
Engine: 5.7
Transmission: 700
anything new in the last 2 years?
Old 04-24-2017, 11:42 AM
  #434
bk2life's Avatar
Car: 91
Engine: 5.7
Transmission: 700
...guess not
Old 04-24-2017, 01:24 PM
  #435
pwessels's Avatar
Car: 87 Iroc Convertible
Transmission: 5-speed
Axle/Gears: G92
I just did a simple single 8" set-up for mine. Sits in just the lower part of the well area.
Attached Thumbnails Let's see your custom speaker boxes!-box-installed.jpg   Let's see your custom speaker boxes!-box.jpg
Old 04-24-2017, 11:27 PM
  #436
treimnitz's Avatar
This went in the rear well of a convertible10 inch RF p2
Old 04-25-2017, 11:43 AM
  #437
bk2life's Avatar
Car: 91
Engine: 5.7
Transmission: 700
why 3 amps?
Old 04-25-2017, 12:11 PM
  #438
pwessels's Avatar
Axle/Gears: G92
Originally Posted by bk2life
why 3 amps?
The front and rear speaker pairs are each powered by an Alpine 3522 40w x 2 amp. The sub is powered by the 100w Zapco mono sub amp.
I switched to this set-up for a couple reasons:
1. The 6 x 30w A/D/S amp I was originally going to run everything from (4 x 30w and 1 x 90w bridged) didn't put out the sound level I was looking for.
2. I thought it would actually be much cooler to run an all period correct Alpine system if I could. These old Alpines are really great sounding and put out very decent power for their rated size. I may swap out the Zapco to an Alpine amp at some point as well.
Old 04-25-2017, 12:33 PM
  #439
ILMODC's Avatar
Love it. I was going to run a freshly rebuilt Cerwin Vega Stroker. Dub it "Period correct". lol.
Old 04-25-2017, 02:54 PM
  #440
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Looks nice. Is that 3//4" MDF? Can you post the measurements? Do you know the square dotage of the interior? I might like to make one myself.
Old 06-03-2017, 10:54 PM
  #441
jay123's Avatar
Car: 1991 Firebird
Engine: 5.0 TBI
Hotrodboba400
12-10-2019 07:07 PM
HP52TA
02-03-2018 10:51 PM
Ranbo108
09-09-2015 12:20 PM
84 TA NV
09-06-2015 08:02 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Let's see your custom speaker boxes!
