no constant power to new radio where did i screw up??
Car: 1984 z28--1987 LT
Engine: 305HO
Transmission: turbo350
hey fellas
i just put in a jvc head unit in my 87. everything works fine except i have no constant power to the radio so when i shut the car off i lose all me pre-sets and clock time any ideas? i appreciate any help thanks
Car: 2003 SILVERADO /86 IROC/85 S10
Re: no constant power to new radio where did i screw up??
Take a volt meter and check the wires you hooked up. Did you use the cars harness? You can also just run the power wire from the radio to a spot that is marked "batt" on the fuse box.
Engine: 305HO
the constant power wire is on a white connector not attached to the harness . there's only the yellow wire, and no other. right now the yellow wire is spliced together with the red wire.
I think you should separate the two wires and use the yellow one(I think) to power your memory for the clock and presets.
Thats your problem. The yellow is ignition 12v(+), meaning it will only give power when the key is in the ON position. If you want your presets saved, run a 12v(+) constant to the necessary wire on the radio. Sounds like your missing part of your wiring adapter kit.
Engine: 305HO
do you mean the red wire is 12v ignition? there was a yellow wire connection seperate from the harness in the install kit , it fits a connection thats was connected to the stock radio, that connection off the cars wiring harness has a orange and brown wire.
1 Post
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
If your looking for a constant wire to save your presets and the one that is meant to be used isnt hot instead of running a whole new wire to the battery just tap into the constant wire in the cig lighter. Works just the same!
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
only one prong gets power, the prong that is being used. Described exactly the same way above. Im also having trouble with power on a new radio, but it does not power on at all.
EDIT: PROBLEM SOLVED!!!! that pink wire in original harness was not constant power, it was antenna power. Found my constant power wire, some how it was bad. Fixed by grabbing power at that weird orange&black plug in location. I just took off that wire nut that was connecting wires for nothing and spliced in there. Worked like a charm!!
Car: 85 IROC-Z28
Engine: 305 but want ls
Transmission: 700R
Same problem here!!! Used meter tester and yellow is my 12+(red) but can't find constant power right now so just ran both but it's annoying. How do you tap fuse box for constant power? HELP
Car: 84 Trans Am
Does anyone know what the hell this thing is? My car has the exact same thing.......
1992 Trans Am
05-10-2023 07:19 PM
sailtexas186548
08-24-2015 10:11 PM
