Replacing stock 4x6's with 2 ways?
Old 05-16-2010, 09:32 PM
86NiteRider's Avatar
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I have some used 4x6 Pioneer TS P461 2 ways. I want to replace my stock 4x6's. The Pioneers have a two prong wire that comes out the Tweeter. I also need to run a two prong wire from the woofer as well. Can I splice the woofer and tweeter wire into the wire that runs to the stock radio? Or do I need some type of crossover?
Old 05-16-2010, 11:11 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Replacing stock 4x6's with 2 ways?
To get a decent sound you need a cross over. It kinda defeats the purpose of having a separate woofer and tweeter if you send the same frequencies to them both.
Old 05-16-2010, 11:12 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Old 05-17-2010, 06:34 AM
Axle/Gears: Posi
Any recommendations on brands and potential cost? Also where should I place the crossover as in best location so I have no rattles?
Old 05-17-2010, 01:25 PM
travis401's Avatar
Car: 91 Camaro RS
Everyone will have an opinion on what they think the best crossover is. Its all mostly personal preference. I dont run a crossover so I cant suggest what I use. However, it doesnt matter where you put the cross over, just know that it takes one input wire for each speaker, and has 2 outputs per speaker with 2 wire per output. (hi and mid/low, pos & neg). So its usually easier to mount them near the speakers so the youre not running a lot of wires through the car.
Old 05-19-2010, 10:20 AM
Axle/Gears: Posi
Thanks. I am going to pick up one today.
Ghettobird52
12-29-2023 08:23 AM
dutch930
09-11-2015 06:58 AM
TheExaminer
08-26-2015 04:59 PM
marcusaw
08-10-2015 08:13 AM
Quick Reply: Replacing stock 4x6's with 2 ways?
