Original Delco Radio with MP3 module
Old 11-09-2012, 08:22 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Hi
That was an original radio
and that was look after
I made a video but I was record it by my phone and it is very poor quality (darknesses)
As I wrote before if someone will be interested to built it - I can help
Old 11-09-2012, 11:37 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Original Delco Radio with MP3 module
Why not just buy one that's been modified already?
http://www.ebay.com/itm/190648617532...84.m1423.l2649
Old 11-10-2012, 02:25 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
The first thing is differences between 7$ for this module and 195$ for that complete radio is quite big. The second thing is that if buy radio from ebay you don`t have thirdgen looking radio anymore. The third thing is you must have external mp3 player, with this radio you get only wire minijack and aux socket.
Old 11-10-2012, 03:53 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
If you think that thing will look stock you're kidding yourself. Good luck trying to install it.
Looks like you'll have to cut up the faceplate of your stock radio to get that circuit board in so it will mount flush. The YouTube video sounded terrible. That 4th gen radio looks more stock than that thing is going to look and sound a 100 times better, You get what you pay for.
Old 11-10-2012, 04:21 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
thats your opinion
I`ve already installed it in two cars and works great, what you see on last pic is already assembled
You don`t have to cut anything. I designed front plexi and cut it on laser
Old phone and dark place, I will record it better camera
Why do you think it will work better than this? The 4th gen radio looks like a crap.
Old 11-10-2012, 08:26 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I think it's cool. I have a background in car audio install and can appreciate your work. If you're looking to keep the stock radio it's certainly one option. My only issue is that there are better resources available such as an istreamer.
Old 11-10-2012, 01:20 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
what is istreamer ? I`m not US citizen so have problems with English, I haven`t use that language for last 11 years
ok, I found what is istreamer
Old 11-12-2012, 01:25 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
it is way expensive and you still need an iPod or iPhone to use it.
Old 11-12-2012, 02:10 AM
greekknight's Avatar
Very cool!!
Old 11-14-2012, 03:27 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
There`s a better quality movie
Old 11-15-2012, 02:14 AM
http://youtu.be/Rt7k5AT-0IY
Very good!
Old 11-15-2012, 06:03 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
I went and picked up a 4th gen radio from a 2001 Camaro that has the CD changer option. I then picked up a GM-AUX9 adapter which as an input for my IPOD. This adapter plugs into the harness behind the radio and uses the CD changer option to run it. So when I want to listen to my ipod, I just switch to the CD changer mode on the radio. The only modifiations that needed to be done were to enlarge the radio faceplate to fit the newer radio which has a slightly larger face, and drill new bolt holes because the ones for the 4th gen stereo aren't in the exact same location. They're hidden though so you don't see them.
Old 11-15-2012, 01:20 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
I built that to not have an external device such an ipod connected via aux. I used that solution for last 9 years.
Old 11-16-2012, 01:59 AM
Noone's Avatar
Hi Levy!
Sounds nice!Have you pictures how you make this?
thanks
Old 11-16-2012, 05:27 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
ok I will try to translate it, if something will be not understand - let me know
cut on CNC plexi 2mm of the front window, if someone is interested email me I have file with that window
take off push buttons
take off the top cover
unscrew the tuner PCB
unplug the wire which have plug, the rest wires just cut
glue the holders on back side of front mask (holders come with mp3 module)
cutoff VFD display (in my radio - red wires)
Old 11-16-2012, 05:28 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
deleted
Old 11-16-2012, 05:53 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Cool mod!
Old 11-16-2012, 08:05 AM
Noone's Avatar
Hi!
Thats cool!
Where did the line outs from the mp3 module goes?
thanks
Martin
Old 11-16-2012, 08:10 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
to the 3rd and 4th cable from the wires that was pluged to the tuner PCB which was disconected, on the last pic you have marked in red circle
Old 11-16-2012, 08:25 AM
Noone's Avatar
Hi!
Thanks. From witch side?
Did you only connect left and right?
Where goes the ground from the line out?
thanks
Old 11-16-2012, 08:33 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
you count from front of radio
I connect only left and riight via 1uF capacitor to protect the module
You don`t need to use ground
Old 11-16-2012, 08:47 AM
Noone's Avatar
Hi!
Thank you very much.
I also have such a mp3 board, the only problem is that you can´t switch between the folders. So i search for a long time for another sound modul that i can use with this radio.
thanks
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
That is really cool, the only thing that bothers me is to cut through the original faceplate. The red screen is perfect for a Pontiac.
I guess the USB ports could be removed from the PCB and placed somewhere else at the end of some wires. And I could do without the card reader.
Or, seeing how it's made, simply wire the screen and glue it on the back of the original one, and place the rest of the unit wth the buttons and USB/card slots in place of the ashtray for example.
Do you think you could make a clear schematic to explain how you wired it to the original radio ?
Old 11-16-2012, 08:49 AM
Noone's Avatar
Hi Raptor!
Martin here from austria!
Sounds that the european guys are here!
Martin
Old 11-16-2012, 02:08 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Originally Posted by Noone
Hi!
thanks
Just hold on longer forward or rewind then push twice
Old 11-16-2012, 02:12 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Hi Raptor!
Martin
Hi Martin, I`m from Cracow, Poland. I have a friend who is living in Wien,Austria and he is rebuilding a 87 camaro here in Poland
Old 11-16-2012, 02:25 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
No, you dont have cut anything. The original windowshield can be removed. I draw a new windows shield with holes for USB/SD card in CAD program and cut from plexi by the laser.
USB port can be removed but in car there is a lot of noises from electrical instalation of the car so that could be a problem
What conections are you interested ? Power, Audio, push buttons ?
Old 03-13-2013, 12:47 AM
DARKD3CIMATION's Avatar
Transmission: 5 speed manual
Where can I wire the left and right to a audio jack, I want to plug my phone in via headphone jack but I got nothing when pluging it into the 3rd and 4th wires on the cable circled in red, what do I do I want to be able to use the equilizer?
Old 03-13-2013, 01:54 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
maybe thaht will help
Old 03-13-2013, 01:56 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Subscribed, I can do this in the spring. Soon!
Old 12-22-2014, 01:39 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Little update
I`ve just upgrade my version with Bluetooth option
Sorry for pure version
Old 02-04-2015, 07:37 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Awesome mod! Going to try it for sure!
Old 03-26-2015, 12:53 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
This is a great mod, nice job OP
Old 07-25-2019, 07:26 AM
GiedriusN1's Avatar
Nice mod. Unfortunately my Delco is different model..... I'm looking for internal diagram of 1994/95 Delco 16179102 / 16166661
Old 06-25-2020, 02:58 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Hi everyone. I just want to inform you that radio is still working. I made some other modifications for my friends and they are happy with that.
Last time I swaped into LT1 engine and made some modifications to speedometer. I`m using two stepper motors to make it working. Odometer is working also. It is no longer powered mechanical
During the tests
And after crash of transmission I made a little OLED display connected to ALDL connect which show me temperature of transmission
CorvairGeek (06-26-2020)
Old 06-26-2020, 04:40 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
During the tests
https://www.youtube.com/watch?time_c...ature=emb_logo
https://www.youtube.com/watch?v=OwK0tqzsZCM
That is pretty cool. I would very much like to have a "Driver Information Center" (D.I.C.). My '04 Chevy Crew-cab Diesel dually has one that uses steering wheel controls. It's very useful.
DR.K.
Old 12-12-2023, 03:23 AM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Next revision, original VFD display via I2C protocol
DynoDave43 (12-12-2023)
Old 04-18-2024, 02:14 PM
BlackDev's Avatar
https://www.youtube.com/watch?v=4Y91fUz7lsk
Hi,
I'm from poland. I'm interesting to cooperate with You to modify my radio. Please contact to me or share some contact to You.
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
69 Six Pack
10-05-2015 07:51 PM
OLDYELLR
Car Audio
09-30-2015 07:10 PM
g.l.mos
08-22-2015 12:02 AM
Quick Reply: Original Delco Radio with MP3 module
