Need help with my Delco/Blaupunkt radio
Old 07-08-2013, 12:14 PM
DrNBody's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
My car has the 16051921 Delco 5-band equalizer/Blaupunkt tape deck radio. It's the original radio, and the tape player is acting up.
As soon as I put a tape in, it pops back out. It doesn't even hold it in for a split second. But, if I do push it in and hold it there, it likes to go forward/backward and that's about it, but does not play.
I just took the unit out and took it apart, and the belts seem perfectly fine. When I rotate the motor gear, it moves all the belts and pulleys etc. What I do notice, is that when I push the clips and move the unit in (as a tape would when inserting), it does not hold the unit together/in.
I've searched on google and ebay for parts or anything relating the Delco part number and Blaupunkt part number, and I cannot find anything.
Any help here? I know of two places I can call up and send the unit too, but right now I rather try to fix it myself by getting correct parts or replacing the Blaupunkt tape deck part inside the radio.
Old 07-09-2013, 12:31 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Need help with my Delco/Blaupunkt radio
The search engine here has good information.
https://www.thirdgen.org/forums/car-...ette-deck.html
Old 07-17-2013, 03:48 PM
DrNBody's Avatar
Engine: LB9 305 TPI
Bought replacement belts, did them, and still the same thing. Anybody?
Old 06-25-2014, 12:16 PM
Radio Rob's Avatar
Did you ever find help with your Delco radio?
Old 06-27-2014, 09:00 AM
DrNBody's Avatar
Engine: LB9 305 TPI
Nope! Still not working right. A buddy of mine gave me two radios for these cars, I'm going to try and swap the tape deck from one of those in mine.
Old 06-29-2014, 02:16 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
You're talking about the factory deck with the equalizer right? That didn't have anything to do with Blaupunkt...?
Old 06-29-2014, 02:59 PM
Radio Rob's Avatar
I was talking about the Blaupunkt. Can you send a picture of the radio. I'm sure I could help you with this
Old 06-29-2014, 03:05 PM
Radio Rob's Avatar
Text me the pic 7273488791
Old 07-03-2014, 03:50 PM
DrNBody's Avatar
Engine: LB9 305 TPI
Its this radio:
I opened it up and changed the belts, and it was in fact a Blaupunkt radio.
Old 07-03-2014, 03:56 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
It's a USA made Delco... still have no idea where German/China Blaupunkt is coming from.
Old 07-03-2014, 04:24 PM
DrNBody's Avatar
Engine: LB9 305 TPI
Inside the radio, the metal casing that is stamped Blaupunkt, its also stamped "Made in Germany"
Old 07-03-2014, 07:01 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well cool, I stand corrected... I've never heard of that!
Old 07-03-2014, 08:47 PM
DrNBody's Avatar
Engine: LB9 305 TPI
Damn lol!
Old 07-03-2014, 10:42 PM
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
It's made by delco.. They used a few blaujunk parts.
Old 07-20-2014, 08:57 PM
bubbazwv's Avatar
Car: 1987 Camaro SC
Engine: 2.8
I have the same radio...cassette is doing the same thing let us know if you find anything....Im actually thinking on doing the jack for I-pod or a phone..3.5mm jack
Old 08-13-2014, 11:14 AM
DrkHwk's Avatar
Car: 02 Hawk
Engine: 427
Axle/Gears: 3:42
I recently disassembled my blaupunkt unit and a seemingly similar unit from a newer 94 s10. There were a lot of differences, mostly in the cassette section of the radio.
Old 08-14-2014, 10:35 AM
DrNBody's Avatar
Engine: LB9 305 TPI
I did the 3.5mm jack, was a great mod!
hectre13
Car Audio
26
03-03-2022 05:38 PM
RS Reaper
10-17-2018 07:52 PM
Fireslash
04-11-2016 06:43 PM
Gunner242
12-25-2015 04:49 PM
John in RI
Car Audio
09-10-2015 11:24 PM
Quick Reply: Need help with my Delco/Blaupunkt radio
