1988 Trans Am front speakers?
Old 07-29-2014, 12:37 AM
dibella989's Avatar
Car: 1988 Trans Am GTA
Transmission: 5-Speed
Axle/Gears: 3:45
Have 1988 Trans Am GTA, owner before me took out all old speakers and replaced with sonys, I'll probably swap for alpines. Also has 2 12" subs, but there are no speakers in the front. As in all sound comes from behind the seats, and I feel like this isn't right. Were they taken out or never actually in the car? And how difficult would it be to add them in?
Old 07-29-2014, 07:28 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Re: 1988 Trans Am front speakers?
Front should have speakers, very simple to put back in. ( I believe it's 4 screws on-top of the dash, haven't replaced mine yet.)
If you are going after market, crutchfield.com has 4x6 alpines with adapter wire that will make them plug right in.
If you want to go stock, gmpartscheap.com
Old 07-29-2014, 12:14 PM
dibella989's Avatar
Axle/Gears: 3:45
Thanks, exactly what I wanted and needed to hear. I'm going with alpines
Old 12-05-2014, 12:42 PM
kuddybing's Avatar
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
They should be 4x6's and alpine does make a speaker that mounts right in most aftermarket 4x6's mount to deep but alpine and pioneer makes some that fit like gloves..... theres more then four screw like 8 and 3 r 4 in the defrost vent but once u get em out it comes right off takes like 20 mins with a brew in hand lol hope this helps u out man
Old 12-05-2014, 02:26 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I have these in my 88 GTA
$79.99 pair @ Crutchfield Alpine SPS-406 4x6 Dash
Old 12-05-2014, 03:02 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Just be careful on the magnet size for the front drivers speaker location as the top of the dash might interefere, it did on my 87 TA with JBL speakers.
As a fix, I picked up some Aura home drivers (3.5") and a set of Pioneer tweeters. I fabbed up a plate, cut some wire and reconnected everything.
Old 12-05-2014, 03:35 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Those are the ones should work well and like I said pioneer makes some that fit good.... u can space the driverside a lil bit so u can use speakers with a magnet mount depth more then 1.75 if I reamber right some people on here have cut the dash and vent work up to fit bigger speakers but u can do the same with spacing it a lil bit
Old 12-05-2014, 03:44 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Good job on them plates man thats kinda like what im doing except il be using 4 inch woofer and my tweeter will be mounted on the pillars facing the back of the car with the crossovers mounted under the dash
Old 02-28-2015, 09:47 AM
coav8or's Avatar
Car: 84 pontiac t/a, 87 buick GN
Engine: 5.0
Axle/Gears: stock
The fronts are 4x6 & rears 6x9?
Old 02-28-2015, 10:18 AM
Car: 89 IROC
Correct.
Old 03-01-2015, 06:04 PM
deadtrend1's Avatar
I normally use a heat gun and slightly mold the plastic duct underneath to fit the magnet
Old 03-07-2015, 11:49 PM
dibella989's Avatar
Axle/Gears: 3:45
The vents that cover the speakers, how does one go about getting them off? I tried just prying them off with a screwdriver way back when I posted this, but they appeared to be screwed in from underneath. Is this a job that would require the whole dash be taken apart? Or am I (hopefully) mistaken?
Old 03-08-2015, 08:22 AM
deadtrend1's Avatar
Dont pry. Whole daspad comes out. 4 screws around the defrost vent (I hold a magnet so i dont drop them), and a couple underneath the front lip.
Old 03-17-2015, 03:26 AM
siling's Avatar
google
Old 03-21-2015, 09:07 AM
SOCAL-Z's Avatar
Car: 87' IROC
Good ideas, heat gun to shape duct work and the magnet to catch the dash screws.
1992 Trans Am
05-10-2023 07:19 PM
Reddeath210
10-06-2015 08:20 AM
kyleb24
08-15-2015 08:24 AM
stalkier
08-13-2015 12:59 PM
stalkier
08-07-2015 04:49 AM
Quick Reply: 1988 Trans Am front speakers?
